Rear suspension ?
I would really like to see some pics!!!!
There are several threads in the archives and articles about DIY alignment. I have never tried it, but many forum members do their own without mega expensive equipment.
bottom line, its normal
You guys think it might work for what you want to do? That is, before taking it to an alignment shop.
Even if the machine they use measure to 3 decimal points, it doesn't mean they can adjust to it. They could make a reading, back the car off the machine, drive it back on, and the readings will be different. Shims only come in certain thickness, so they are stuck using what is available. They nomally do not have any passenger(s) in the car. Have them do an alignment to the thousandths of an inch and sit in the car and watch the numbers change.
The caster/camber gauge is fairly accurate, I believe to a 1/4 degree. No need to take it somewhere and pay $100-$200 to have them set it to 1/4 degree.
I only ever had one car aligned at a shop. I was having new tires put on. The cost of a front end alignment for $29. A four wheel alignment was $39. I said do the four wheel. After they were done they said the rear was out a little but there were no adjustments for it (rear wheel drive car). I thought to myself 'Why did they do a four wheel alignment knowing only the front were adjustabel?'. I guess it was for the extra $10 they put in the bank.
Once you buy a gauge you will never go back to a service center. Create a level surface, pull the dust cap off, attach the magnetic gauge, take the reading, and adjust shims. If the suspension was taken all apart, it will take a little longer the first time. Doing it later is much quicker since things will be much closer to begin with. The most difficult thing is setting the thrust angle of the rear. I use Norval's way using a laser beam.
they always look like that when u let em down from the jack! Drive it, They'll straighten up
