fan clutch eliminator
Old Aug 27, 2006 | 11:10 AM
tamvette68's Avatar
tamvette68
Default fan clutch eliminator
has anyone tried the fan clutch eliminator from CC??? any good? comments?? etc....
Old Aug 27, 2006 | 11:30 AM
rihwoods's Avatar
rihwoods
It's just a spacer that allows your fan to turn at all rpm's...not a good idea as some stock Corvette fans are not designed to operate at certain high rpm's without a clutch...like my 78 7 blade...I would think you must consider the type fan first.....
Rich
Old Aug 27, 2006 | 02:10 PM
StickShiftCorvette's Avatar
StickShiftCorvette
Why do you think any GM fan cannot run at 6500 RPM (plus some design factor)?
I thought the clutch fan system was strictly for improved efficiency and reduced noise when the flow is not needed.
Old Aug 27, 2006 | 02:37 PM
rihwoods's Avatar
rihwoods
Depends on pitch of fan,as I understand...
Old Aug 27, 2006 | 11:28 PM
StickShiftCorvette
The pitch of the fan shouldn't make a difference for structural integrety (the speed it explodes) and the pitch would only effect at which speeds the fan best moves air. A fan with a shallow pitch won't move as much air when turning slowly doing better at higher revs, while an agressively pitched fan will not flow as much air at (some) high speed due to flow separation at the blades.
Old Aug 28, 2006 | 12:15 AM
...Roger...'s Avatar
...Roger...
He wasnt saying it would explode! He was saying (as you said)some fans are not designed for high speed.
Old Aug 28, 2006 | 10:08 AM
rihwoods's Avatar
rihwoods
You are better at this than I am...I'm trying to learn to be more "clear" when typing my comments...
Sorry Stick shift...it's in my mind...but getting it communicated here typing with one finger,and all.......
Rich
Old Aug 28, 2006 | 05:13 PM
w1ctc's Avatar
w1ctc
I had one that was locked up (bubba style) it made so much noise that sounded like a truck. I would guess that non-clutch OE fans have less pitch.
To fan clutch eliminator
