center gauge cluster lights
Old Aug 27, 2006 | 11:56 PM
clintwilson's Avatar
clintwilson
Default center gauge cluster lights
i have a 1980 4spd .my center cluster lights dont work. all other interrior & exterrior lights work. fuses ok. poss. ground?.
Old Aug 28, 2006 | 12:00 AM
7T1vette's Avatar
7T1vette
Likely a ground problem. Grab a piece of wire and run from a known good ground point (something under the dash???) to an area of chrome on the dash plate. Turn on the lights and see if the "dummy" ground makes any change. I'm guessing they'll light up!
Old Aug 28, 2006 | 02:38 AM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
The gaguge cluster is all plastic so this won't work. Has the gauge cluster been out? The printed curcuit is kind of flimsy & the power connector for the lights might not be making contact. I'm putting my 79 back together now & I had to glue all the printed curcuit fingers down. If I hadn't then one of them could easily become misaligned. The ground plane is common so if the gauges are working then ground is OK.
Old Aug 28, 2006 | 03:40 AM
clintwilson
Default center guage lights
thanks for the info. cluster has been out (new radio with cd.previos owner.) thanks again.
Old Aug 28, 2006 | 06:57 AM
jdp6000's Avatar
jdp6000
The power to the cluster lights is carried on one of the copper strands on the board. If its moved or marginally misalligned the lights will not work. Take the cluster out. Take a close look...you'll find the problem one. Plug it in while its out...wiggle it...etc.
Jim
Old Aug 28, 2006 | 08:07 PM
cmac72's Avatar
cmac72
If you find that one of the strands on the board is broken you can cold solder it (if they even make that stuff anymore) or do what I did to get my temp gauge, make a jumper cable to bypass the offending part.
Old Aug 28, 2006 | 08:56 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Originally Posted by cmac72
...or do what I did to get my temp gauge, make a jumper cable to bypass the offending part.
I did that to my gauges when I fried one of the circuit traces. Much cheaper than buying a new IC. Been working fine for about 10 years now.
To center gauge cluster lights
