Alum Calipers - Experience?
Old Oct 18, 2006 | 01:23 PM
flynhi's Avatar
flynhi
I recently installed Wilwoods (Telledega fronts, Blackhawk rears) from Corvette Engineering on my 71 with PS Engineering 17" Halibrand repros. These wheels are similar in appearance to the wheels used on the C2 Gran Sports.
With the OE calipers, I had about 1/8" clearance between the calipers and the rear of the spokes of the wheels. With the Telledegas on the front, I now have about 3/8" clearance and with the Blackhawks on the rear I now have about 3/4" clearance.
No guarantee that you will have the same results.
Old Oct 18, 2006 | 01:39 PM
Bee Jay's Avatar
Bee Jay
Wilwoods from Keith.
Old Oct 18, 2006 | 03:55 PM
MBD02's Avatar
MBD02
Cruising
Originally Posted by 427V8
Yes C3 have the same issues as C2 with disk brakes. They are the same setup.
Corvette Engineerings Laguna kit uses Wilwood Narrow Dynalite calipers which have lots of clearance.
They actually sit below flush as compared to the surface of the hub rather than sticking way out like stock calipers.
They are what's behind the Craigers in C3 Strokers wheels.
Yes, I am associated with Corvette Engineering
Keith
Is there a website for Corvette Engineering? This seems like the best solution for this issue. Since I will be replacing all these items anyway. Thanks for the reply.
Old Oct 18, 2006 | 05:03 PM
68/70Vette's Avatar
68/70Vette
Originally Posted by 999
Have SSBC, direct mount and factory look was a plus, poor workmanship. George
Poor workmanship??? Anything specific to mention?
Old Oct 18, 2006 | 05:38 PM
l88rocket's Avatar
l88rocket
Baer and fit great and stop on a dime.
Old Oct 18, 2006 | 06:48 PM
70 LS1's Avatar
70 LS1
OK, lets see a picture. No one around here seems to think Baer even makes a kit.
Old Oct 18, 2006 | 08:14 PM
l88rocket's Avatar
l88rocket
It won't let me post pic's,baer as them listed on there website.
Old Oct 18, 2006 | 08:16 PM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
YEP!
http://www.corvettengineering.com
Old Oct 18, 2006 | 09:59 PM
75 Hot One's Avatar
75 Hot One
I've got SSBC Force 10 as well and didn't notice any "poor workmanship" although I did have some difficulty getting a leak-free connection at the hose banjo fittings. I'd be interested in learning about what poor workmanship you noticed.
Old Oct 18, 2006 | 11:09 PM
StickShiftCorvette's Avatar
StickShiftCorvette
I have SSBC aluminum calipers and they are MUCH MUCH better than stock. I have had some problems with leak on one caliper, but they didn't leak so bad as to trip the warning light only give uneven braking force.
SSBC also fixed the problem caliper twice at no charge except for shipping charges to them.
I didn't like that they don't (or didn't) offer a stainless rear brake line.
Old Oct 19, 2006 | 02:25 AM
davidarborg's Avatar
davidarborg
I use SSBC, 48 mm front and 43 mm rear, night and day compared to stock brakes, nice but expensive.
Old Oct 19, 2006 | 11:08 AM
68/70Vette's Avatar
68/70Vette
I too was pretty surprised that they don't sell a rear brake line. A stock stainless steel brake line isn't going to fit.
I bought my ss brake lines from InLine Tube (Michigan) and returned the standard ss rear brake lines to them. They modified them, per my instructions, to fit the SSBC rear calipers exactly. Very reasonable small fee.
On the stock iron calipers, the brass 90 degree brake line coupling block faces backwards and the stock brake lines make a 180 degree loop to attach. I rotated my brass coupling and had it face forward and had the ss brake lines shortened to directly into the block.
