Replacement Carb
Old Sep 10, 2001 | 01:29 PM
70LT1's Avatar
70LT1
Cruising
Default Replacement Carb
My 1970 LT1's Holley is ready to be replaced. I want a brand new card, not a reman. What are my choices?
Old Sep 10, 2001 | 02:53 PM
e3pres's Avatar
e3pres
St. Jude Donor '08-'09
Default Re: Replacement Carb (70LT1)
I've heard alot of good things about Demon carbs :reddevil . They're basically a Holley that has been massaged by Barry Grant. If a demon would fit under the stock air cleaner of my '79, thats what I'd be running. Just my $0.02.
Old Sep 10, 2001 | 02:59 PM
Alwyn678's Avatar
Alwyn678
Edelbrock has been a great performere for me.......but I know this forum is partial to Quadrajets massaged by Lars :D
Old Sep 10, 2001 | 04:50 PM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
Assuming that you don't have an NA9 optioned 1970 LT-1, the carburetor for your application (Holley LIST R 4555 A) is still available brand new from Holley. Pretty expensive from what I recall...
If you have the original date coded Holley, I'd personally send it out to Jerry Luck and have him rebuild/restore it. It will look brand new and work better than any "out of the box" carburetor... Most likely for a lot less money.
Regards,
Old Sep 10, 2001 | 05:30 PM
Gordonm's Avatar
Gordonm
Default Re: Replacement Carb (Rowdy Rat)
I have a 750 DP on mine. I bought it brand new. If I were to do it again I would go with the Demon carb. A good carb for a few more dollars than the Holley
Old Sep 11, 2001 | 01:02 AM
LT1driver's Avatar
LT1driver
Default Re: Replacement Carb (Gordonm)
I agree with the Jerry Luck sugggestion, otherwise if original carb, make sure you keep it. :D
To Replacement Carb
