Signal Light Help!!
Old Sep 1, 2006 | 08:31 PM
kidneyboy's Avatar
kidneyboy
Default Signal Light Help!!
When I use the turn indicator nothing happens, both sides front and rear. They illuminate but don't flicker. Headlights on or off makes no difference. It's a 78 SA. Any ideas, suggestions, etc. would be greatly appreciated. Thanks in advance.
Old Sep 1, 2006 | 09:07 PM
7T1vette's Avatar
7T1vette
Since both directional signals show no flash, it has to be the flasher unit. On my '71 it's located behind the right side dash panel. Hope that helps.
Old Sep 1, 2006 | 09:09 PM
c3 in hawaii's Avatar
c3 in hawaii
Did you check the flasher? I had this problem on my '78
To Signal Light Help!!
