How Can This Be?
Old Sep 2, 2006 | 09:57 PM
vette4820's Avatar
vette4820
Default How Can This Be?
Doc Joe here. Can't seem to log in on my site..4820 is my son's moniker.
A few posts back, I was bragging about my new 2004R transmission.
It really has been great until today. On the freeway, I noticed some scattered smoke out the rear window. Then a moderate ***** ***** sound, and the transmission completely stopped. It was if I was in neutral. I had to glide off the freeway...good thing I was in the far right lane.
I wrote a scathing email to the trans shop...advising them they are going to put in a new trans, and pay for towing my vette 60 miles to Hungtington Beach.
Anyone have any ideas what could have happened? This is a completely new trans. Could the differential be the culprit? Never gave me any problem w the old TH300.
Since the install, my speedo went out (suspect the speedometer gear),
my oil pressure gauge is pegged all the way to the right, and my air conditioner blew a seal.
Please respond...I'm really suffering over this.
Doc Joe
Old Sep 2, 2006 | 10:27 PM
tracdogg2's Avatar
tracdogg2
Have someone start it up and put it in gear while you are looking at the driveshaft. PLEASE be very careful. See if the driveshaft is turning. If it is the diff is toast. If not it's the trans. First make sure the driveshaft is still attached.
The oil pressure may be the wire is off. With the trans out the back of the motor will dropped and the sending unit will hit the firewall. It will be a round bell on the drivers side under the distributor with a blue wire going to it. AC and speedo? Hard to say without looking at it.
Mike
Old Sep 2, 2006 | 10:36 PM
marshrat99's Avatar
marshrat99
Who's 2004R? Did ya check the tranny fluid? Possibly blow a line?
Old Sep 2, 2006 | 11:25 PM
vette4820's Avatar
vette4820
Default yep
Am I replying in the correct spot? There is no loss of transmission fluid.
Old Sep 2, 2006 | 11:48 PM
SIXFOOTER's Avatar
SIXFOOTER
That sux, does the car lock up in park? If so, its not the rear end. May have a clutch in the tranny turned loose. If the fluid is full and the shaft doesn't turn when in gear and it locks up in park, it can't be anything other than the tranny
To How Can This Be?
