Help!!! Bad Rear End Fitment
I put a 69 frame under a 71 roadster and all fit and aligned up well. I used two guide pins and all of the bolts went in properly. The body fits real nice with good door alignment and operation.
I put new rubbers mounts in the rear end cross member, bolted it to the rear end and hoisted it in place. WOW!!! The rear end seems to be about 1/2" to 3/4" too far forward. The front snubber mound does not line up at all and the driveshaft yokes are hitting the body.
I was under the assumption that the frame 69 to 78 (except for the crash bumpers) are the same. If not then either: 1) the rear end cross member is wrong, 2) the rear end back cover is wrong, or 3) the frame is screwed up.
I am baffled and need some expert advise/opinions before I go crazy over this one.
I have pictures but could not figure out how to post them.
Many thanks,
Joe Germann
This really boggles my mind. Mounting of the rear end center section has absolutely nothing to do with the mounting of the body.
Are there any differences in back differential covers - year to year?
Are there any differences in cross members - year to year?
The frame I have is an automatic frame in a standard shif car. Other than the clutch shaft mounting tab and a removable trans cross member it should be identical. Right?
How can this NOT fit? If it is NOT an improper cross member or differnetial cover, the only fix I can see is to modify the cross member to push the rear end towards the rear of the car.
Joe
