Trailing arm bearings
Old Sep 5, 2006 | 11:15 AM
427basketcase's Avatar
427basketcase
Default Trailing arm bearings
Is there a wat to lube these? I don't seem to see anything there. The AIM is a little vauge there also.
Old Sep 5, 2006 | 11:19 AM
SIXFOOTER's Avatar
SIXFOOTER
not really, Its a bushing, not a bearing. If its squeeking it probly needs replacing unless its new(ish) You can possibly pull the pin bolt and lube it with some Lithium grease.
