update on heater core leak
Old Sep 5, 2006 | 05:53 PM
corv58's Avatar
corv58
Default update on heater core leak
good news: once i got her up in the air, i saw that the leak was in the hose from the block,but the coolant was running along the backside of the hose...after removing the air cleaner assy., i found bubba had left his mark.......he had installed one of those plastic tee fittings (for backflushing the system ) .... the hose clamp was tightened up too close to the end of the fitting and flattened it a little,causing a slight leak... i'm sure it would have gotten worse on a long drive......sometimes you get lucky....cost $3.54 for a new fitting......education:priceless.....:ch eers: jim...
