Ordered a 5 gallon fuel cell..
Old Sep 5, 2006 | 10:38 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Ordered a 5 gallon fuel cell..
Ordered a RJS 5 Gallon fuel cell as also the -8 AN fuel line kit.
Once I'll get it, I'll convert my fuel system to #8 fuel lines to solve possible issues/future issue with fuel delivery.
OK, now here's my question:
The fuel cell has two -8 AN outlets and one -6 AN outliet for the overflow. Should I plug one of the -8 AN outlets or should I run a return line? Right now, I'm not running a return line and I don't know if I should?? So, can I just plug the 2nd port or would there be any issues..
Also, the -6 AN outlet on top, should I run a line to a overflow container?? If not, where else should I route that line?
Any help would be appreciated!
Old Sep 5, 2006 | 10:56 PM
davidm_comp's Avatar
davidm_comp
I just got a 16 gallon summit fuel cell. I was planning on plugging one of the 8an fittings and using the other as supply, and using the 6an as the return line.
Old Sep 5, 2006 | 11:29 PM
pef427's Avatar
pef427
Hey Ollie
I used the Aeromotive pump and ran the 2 -8's into a y-block with a -10 forward thru the filters to the regulater. I then routed a -6 back as a return line. Here's a pic.
-Patrick
Old Sep 5, 2006 | 11:35 PM
GrandSportC3
Originally Posted by pef427
Hey Ollie
-Patrick
thanks!! So, did you route the return line into the 6 AN on top of the fuel cell? How is the return line set up at the carb. Is there really a advantage of running a return line?
Old Sep 6, 2006 | 12:44 AM
pef427's Avatar
pef427
Aeromotive recommended it. Something about keeping the fuel cooler and also eliminating vapor lock. Yes I ran the -6 return back to a bung in the top of the tank. The Aeromtive regulator I used has one port for incoming fuel with two ports for out-flow to the carb and one port for the return including a port for a fuel pressure gauge.
I used 2 -8's from the regulator to each end of the 1250 without a fuel log. Check their website.
-Patrick
Old Sep 6, 2006 | 10:55 PM
GrandSportC3
-Patrick
hmmm.. if the return line goes back into the fuel tank, it would be a closed circuit and the fuel cell is supposed to be vented because the cap isn't vented..
Old Sep 6, 2006 | 11:32 PM
pef427's Avatar
pef427
So you're saying if you didn't run a return line the top port would be used as a vent???
Check with the tank manufacturer and see what is supposed to act as a vent in the system when the return fuel line port is used. With a high volume/pressure pump there is more need than ever for a return line.
-Patrick
Old Sep 7, 2006 | 11:05 AM
GrandSportC3
-Patrick
Patrick, do you have any pictures of the return line setup at the carb/regulator?
I always thought that the overflow port on top is supposed to be routed to a overflow canister/catch can...
I'm still wondering about the fuel system not being vented with the return line in place.. My current '68 tank has a vented cap.... Don't know how later models are vented because they switched to non-vented caps later.
Old Sep 7, 2006 | 03:59 PM
pef427's Avatar
pef427
I don't have any but I will be working on the car tonight and can take a couple. Again, just make a call to Aeromotive tech line.
-P
Old Sep 7, 2006 | 09:01 PM
GrandSportC3
OK, I got the fuel cell and there are no instructions
There's also some sponge like things the fuel cell.. I assume that I'll have to remove those, right?
Old Sep 7, 2006 | 09:12 PM
74droptop's Avatar
74droptop
The sponge is inside of the cell correct? If so that is like baffle to keep the fuel from sloshing around DO NOT remove it.
Also I'm running a return line to the stock tank with a non vented cap no problems, and yes at your power level you need to run a return line per your pump/or tank requirements and it does help keep the fuel cooler and prevents vapor lock.
Old Sep 7, 2006 | 10:23 PM
GrandSportC3
Thanks!!! I was just concerned that the sponge will suck up the fuel and not release it fast enough and the fuel cell will run dry...
BTW - any pics of a return line setup for the carb/pressure regulator would be appreciated!!
Old Sep 8, 2006 | 09:52 AM
pef427's Avatar
pef427
Will do today. I ran into issues last night but I will try to get those pics today.
-P
Old Sep 8, 2006 | 10:06 PM
GrandSportC3
-P
Old Sep 8, 2006 | 11:17 PM
pef427's Avatar
pef427
Hey O,
I had to do the family thing tonight and didn't work on the car. I plan to work on it all day tomorrow. Bare with me one more night. Sorry.
-P
Old Sep 8, 2006 | 11:28 PM
GrandSportC3
Hey O,
-P
Talked with a guy at the local speed shop and they told me that I either need a bypass pressure regulator or a bypsass fuel pump. Is this correct?
Old Sep 9, 2006 | 12:02 AM
74droptop's Avatar
74droptop
Yes, what type pump are you using now, probably ok if you have an electric pump, buy a regulator and follow the directions that come with it, you should be fine. I would run a -10 or -8 to feed the carb and 2 sizes down for the return. Your carb is probably set up for -6 it's ok to run -6 from the regulator to the carb and then -10 or -8 from the tank to the regulator, if you run -10 then the return should be -8 ,if you run -8 to the regulator then the return should be -6.
To Ordered a 5 gallon fuel cell..
Old Sep 9, 2006 | 12:26 AM
pef427's Avatar
pef427
The Aeromotive by-pass regulator I used can also be used for fuel injection. Nice unit.
-P
Old Sep 9, 2006 | 12:58 AM
GrandSportC3
ok, if I'll need a different regulator, I won't run the return line for now... I can change out the regulator later and run the return line...
I have more questions. Will post them in a new thread to get more related answers.
Old Sep 9, 2006 | 04:12 AM
Twin_Turbo's Avatar
Twin_Turbo
If your cell doesn't have some kind of vent on it you will need to add one, preferrably a discriminator valve.
