Small shop press question
Old Sep 7, 2006 | 12:52 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Default Small shop press question
I have one of Harbor Freight's 12 ton shop presses. I've run into a problem trying to install my rear wheel studs - the shaft under the jack is shorter than the rear spindle shaft. Does anyone have a suggestion for whipping up an extension? I need about 2" at most.
Old Sep 7, 2006 | 09:33 AM
justanotherdoe's Avatar
justanotherdoe
Hi Batman
I pulled my wheel studs through from the outboard side using some washers and a lug nut.
Old Sep 7, 2006 | 11:05 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Originally Posted by justanotherdoe
Hi Batman
I'm upgrading mine, and the fit is very tight. The nut trick isn't going to work, it's been tried and failed. I really need to get about 2" more on the pin on my press.
Old Sep 7, 2006 | 12:02 PM
vettfixr's Avatar
vettfixr
How about an impact socket? Will that work as an extension?
Old Sep 7, 2006 | 03:32 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Not sure how I'd hold it rigidly in place. I'll check it out tonight.
Hmm...maybe drill and tap the end of the pin on the press, find a 1" steel dowel, drill and tap that, and use a stud to hold them together...
Old Sep 7, 2006 | 03:40 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
I would use a socket or a piece of steel bar stock cut to the needed length. Just make sure you are very careful about it not slipping out and shooting across the room. Or snap an extension onto a socket that slips over the press shaft. That would be secure and long enough.
Old Sep 7, 2006 | 04:24 PM
SIXFOOTER's Avatar
SIXFOOTER
Use a deep 1" socket, put the stud in the flange, place stud/flange on table with press plate across the bridge, socket over the stud and press
Old Sep 7, 2006 | 04:28 PM
Tom454's Avatar
Tom454
Press them out the opposite way...
Place a socket over the round end of the stud big enough for the stud head to fit into, on the side opposite the threaded part. Press the spindle off the stud, instead of pressing the stud out of the spindle.
Did that make any sense?
Old Sep 7, 2006 | 04:30 PM
Tom454's Avatar
Tom454
You type faster than I do.
I gotta eat some Wheaties.
Old Sep 7, 2006 | 07:15 PM
Joe45's Avatar
Joe45
Would an electrical conduit connector work? It's a tube that is used to connect 2 pcs. of conduit together. Has a screw in each end. I'm thinking if the ID is correct you could mount one end to the press pusher and then connect a piece of bar the same dia. to the other end. Would hold the 2 together and give you your length. Just thinking outloud.
Old Sep 7, 2006 | 08:11 PM
SIXFOOTER's Avatar
SIXFOOTER
I don't think those are tough enough, the socket thing will work fine, asuming he has the press plates
Old Sep 7, 2006 | 09:56 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I press them out with a 3# drill hammer.
Thanks for the advice...I'll try the socket thing tomorrow.
Old Sep 7, 2006 | 11:51 PM
...Roger...'s Avatar
...Roger...
Batman-can you put all 5 studs in and put the heads down on the plates(3 on one and 2 on the other)-then put the press in the center of axle and push all 5 in at once ?Use a brass hammer and tap on face of axle flange while holding pressure with press-then flip over and seat each one with hammer
To Small shop press question
