Leaking Oil
Old Sep 7, 2006 | 04:07 PM
JustinD's Avatar
JustinD
Default Leaking Oil
So My car started leaking oil after my valve cover was removed and put back on. I went and got some new gaskets and put it on the leaky one. Well guess what it still leaks. I found that some tabs on my valve cover were hitting on the head so I ground them down and puto n a new gasket cause the others had dents from the tabs. I took it out and it is still leaking. The valve cover can't be bent because they are cast aluminum. So they'd just break, don't ask how I know... I've never had this problem before and it is becoming a pain in the rear end. It gets on my header wrap and takes forever to burn off leaving tons of smoke all over the place when I come to a stop. What should I do?
Old Sep 7, 2006 | 04:14 PM
SIXFOOTER's Avatar
SIXFOOTER
what kind of gaskets did you get? I think the Felpro Blue ones are the best and are reuseable. Clean the gasket surfaces real well with carb cleaner so its perfectly dry then apply a thin layer of silicone and torq to spek ( got to look it up)
Edit, Moroso
http://store.summitracing.com/partde...5&autoview=sku
Old Sep 7, 2006 | 04:15 PM
JustinD's Avatar
JustinD
Ya, I was using Felpro Corks. If I silicone them then won't it be a mess when I need to take it off? Well those are spendy.
Old Sep 7, 2006 | 05:19 PM
Little Mouse's Avatar
Little Mouse
You have more problems then a christmas turkey, just kidding.
don't go using silicone it breaks loose its in your motor.
Old Sep 7, 2006 | 05:50 PM
JustinD's Avatar
JustinD
Well, I'm about to braze them right to my heads. I'm getting pissed at this peice or garbage. The damn thing is a dog off the line and I still backfires if I floor it below 2000. The trans was leaking. I fixed it and it was good for a few weeks now it is leaking again. It doesn't have anywere close to the horsepower I want. I'm about to do something I'm gonna regret.
Old Sep 7, 2006 | 06:00 PM
Little Mouse
Well the backfire is an easy fix don't floor the puppy below
2000 rpm.
Old Sep 7, 2006 | 06:03 PM
JustinD's Avatar
JustinD
Hey thats no fun.
Old Sep 7, 2006 | 06:07 PM
Little Mouse
You know you have two options the $250 option and the three to
four thousand dollar option.
Old Sep 7, 2006 | 06:10 PM
JustinD's Avatar
JustinD
Rear end gears plus a torque converter? I know that is my next step. First is the leaky valve cover.
Old Sep 7, 2006 | 06:17 PM
Little Mouse
I thought you were going the three to four grand 4 speed rear
gears option. A hughs torque converter is only $180 another
$50/75 for a good trans cooler few hundred for some rear end parts
and your in decent shape. Converting to a 4 speed can get into some money.
Old Sep 7, 2006 | 06:18 PM
JustinD's Avatar
JustinD
yup that is the converter I was gonna go with. The 2500 stall. Then a trans cooler.
Old Sep 7, 2006 | 06:30 PM
JustinD's Avatar
JustinD
I'm gonna need an instal kit for the ring and pinoin gears. Which one do I need?
http://store.summitracing.com/egnsea...115+4294862355
Old Sep 7, 2006 | 06:46 PM
Little Mouse
RMG-8310241. 63-79 corvette richmond gear instalation
kit. summit catalog page 199 Price $104.95
Old Sep 7, 2006 | 06:55 PM
1BAD80's Avatar
1BAD80
Try some FelPro 1604 valve cover gaskets that are 3/8" thick and very forgiving.
Old Sep 7, 2006 | 07:05 PM
Little Mouse
richmond gear 63-69 corvette ring gear and pinions
RMG-4900231=3.70
RMG-4900311=3.90
RMG-4900251=4.11
I have no clue how good a product they are and you would want to find out if they will fit your carrier. Summit page 201
Old Sep 7, 2006 | 07:25 PM
JustinD's Avatar
JustinD
Nope. This is from the summit website:
1963-1979 Corvette only. When replacing a 2.41 to 3.70 with a Richmond ring and pinion the carrier must be replaced with a carrier from a stock 4.10 or numerically higher.
So It uses a differernt carrier from what I have. I called up Toms Differentials and he said that I sohuld contact him later in the month cause that is when he is getting the 4.11's in.
Old Sep 7, 2006 | 07:29 PM
Little Mouse
If you go with toms stuff he will sell you an instalation kit, whats
the cost on parts from toms??
To Leaking Oil
JustinD's Avatar
JustinD
He was in a hurry. So I didn't ask.
Old Sep 7, 2006 | 07:39 PM
Little Mouse
I found a set of gears for you that would work with your carrier
awhile back but now I can't remember who they were. Called
the guy at the time and he had one set of 390s left.
Old Sep 7, 2006 | 09:14 PM
Little Mouse
you have a PM.
