How much does a c3 body weigh?
Old Sep 7, 2006 | 08:28 PM
73C34me's Avatar
73C34me
Default How much does a c3 body weigh?
Greetings I have a week vac. coming up & am thinking of lifting the body for frame paint, inspection & etc. I have the doors & front clip off already, and will remove the seats. How much does this shell weigh? I would like to lift from the garage truss with come along & body lift straps. p.s. I have 10'-8" ceiling & reinforced bottom chord trusses. thanx.
Old Sep 7, 2006 | 11:21 PM
Little Mouse's Avatar
Little Mouse
No one can probably answer as to how much weight you have left,
with the front end off doors no seats it can't be weighing much,
unless you have nothing more then two by fours running across the
top of your garage you will probably be ok.
Old Sep 8, 2006 | 12:56 AM
Jclgodale3's Avatar
Jclgodale3
But I will say about 850 to 900lbs
Old Sep 8, 2006 | 08:51 AM
shafrs3's Avatar
shafrs3
That's about right. 2x4's would be too small to lift the body. You might consider 2x10's strung parallel to the trusses with 4x4's on the ends to the ground doing the heavy lifting.
To How much does a c3 body weigh?
