Can anyone tell me what would cause engine rpm to cycle between 10K and 5K in park (auto trans). I have a 79 vette, 350 with a Holly four.On the way home today I had to keep it in neutral to keep the engine from stalling. I thought at first...idle adjustment. But now, even in park, it won't idle.
Yes I do. I visually looked for anything obvious and couldn't find any. Thanks for any advice you may give.
Most EGR valves you can put your fingers up inside and feel the diaphram move-make sure it moves freely----If you have a vacumn gun pull a vacumn and see if diaphram moves-----tap around lightly with small hammer and see if it seats itself----At idle you should notice a big differance if it is open or closed-----Or take it off and clean and check it and make sure it holds vacumn and fully closes-its easy to remove.
