Q-jet rebuild question
Old Sep 9, 2006 | 10:29 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Default Q-jet rebuild question
When a carburator is restored, how is the body of the carb cleaned and made to look like new?
is it dipped is some sort of chemical cleaner or bead blasted?
(and I'm not just talking about cleaning off some varnish and grease.)
Old Sep 9, 2006 | 10:54 AM
gerry72's Avatar
gerry72
It depends on what carbs you're looking at. A lot are just spray painted. There are paint kits that will give you the correct color, but the look is obviously painted. You can do the paint yourself if you're not too fussy about the look.
Then there's the expensive way which is to have the carb replated. This isn't something you can't do yourself and requires sending it out to a carb restorer.
Old Sep 9, 2006 | 02:01 PM
SIXFOOTER's Avatar
SIXFOOTER
Eastwood sells the paint
Old Sep 9, 2006 | 11:43 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Zinc Chromate.
Not many shop still recoat the Zinc Chromate for enviromental reasons. Most carbs can be cleaned well enough without recoating. Try Doug Roe's book on "Rochester Carburetors" for cleaning and rebuilding a Q-jet - way too much to type here.
Do u really need a "like new restoration" of the carb? Is it even numbers matching for the car? Is the engine even a numbers match for the car? Or do u just want to adjust it for better operation? Problems as is?
The Q-jet is more complicated/difficult than a Holley type carb and my recommendation is to get Roe's book and tune it up as best as possible just to get familiar with it before u tear it apart.
Good luck and hopes this helps. If you need advice on any particular problem just post. The archives have plenty of good information from others that have travel that road also.
cardo0
Old Sep 10, 2006 | 01:53 AM
RPOZ4Z's Avatar
RPOZ4Z
Yes, it's a numbers matching engine.
Yes, it's the original carb for the car. (date code is correct.)
I have rebuilt a quadrajet before, and I'm no stranger to rebuilding a carb.
the engine hasn't been run in 20 years, the carb has surface rust on the choke plate and on the vaccum secondary plates, and is very "weathered" looking.
that's no big deal, I can bead blast the plates.
but, I'm curious as to how they get the carb to look new.
is the body of the carb bead blasted?
or just soaked in cleaner?
and is it painted that gold color instead of re-plated.
Old Sep 10, 2006 | 04:05 PM
lars's Avatar
lars
If you bead blast the cast parts, you will put a texture into the surface that will never look right again. The commercial builders do this, and their carbs all look like garbage - they destroy the carb.
You can dip the carb in acid, such as the metal prep acid sold by PPG for etching metal prior to conversion coating. If you scrub the carb with a soft bristle brush in the acid, you can remove all the corrosion. You can then dip the carb in PPGs Alodine conversion coating. This is an aluminum conversion coating that will put the brownish-goldish color back on the carb - the exact color depends on the carb and how it reacts with the conversion coating.
Painting the carb with the "carb paint" process makes it look awful. Just my opinion. And if you ever rebuild the carb again, the paint will come off and plug up every oriface in the carb..
Old Sep 10, 2006 | 04:51 PM
cardo0's Avatar
cardo0
Default Thx lars.
I think the rebuild u did on my carb looks great lars and couldn't recall how u finished it. Man i didn't know alodine would do the job. Great news as i have stack of carbs that are gonn'a need it. I need to copy/save this post and thx for chimming in.
IMHO recoating the carb is not normally needed unless the coating is removed/deteriorated from the internals of carb - that really needs the protection. And powder coating the outside of the carb has it place too but best left for experienced pros.
cardo0
Old Sep 10, 2006 | 05:30 PM
Bob Onit's Avatar
Bob Onit
The commercial builders are just that. Slobs at best
With a good core and proper glass beading and the proper coating there is no texture,
I have one and I have seen 30 year old OEM Qj's still in the box...
Looks Identica other than a possible difference in color.
And before anybody bashes me for disagreeing with Lars I can say I have a ton of respect for his work and talent and I look forward to any of his posts which I usually copy and put in a folder named Lars.
Old Sep 10, 2006 | 07:26 PM
RPOZ4Z's Avatar
RPOZ4Z
so glass beading would work if care was taken......
I'll look into the acid dipping and alodine conversion coating, sounds like a good way to go.
I just didn't know if glass beading a carb was an acceptable thing to do, I didn't want to take the chance of getting glass bead into the passages of the carb and ruin it.
Thanks everyone for the info!
To Q-jet rebuild question
