2 Holley questions
1) What would cause the vacuum secondaries to stay closed even at high rpm. I have plenty (17-18) of vacuum at idle. The carb has just been thoroughly restored (6239). I can open them by hand but when I rev it by hand and watch the secondaries - they don't seem to be opening.
2) Secondary float is continuously binding up causing flooding. Any suggestions here beside pulling the needle & seat every week and re-adjusting...
Dave
Holley floats can be reliable enough for a daily driver......I'd look at replacing the float and making sure the new one doesn't bind in any way thru it's swing.
Simple reason why is the secondaries are suppose to open during hard accelleration and at WOT and that is precisely when there is virtually no manifold vacuum present. on the other hand, it's that same time of operation that you have the most air & gas flowing thru the carb and producing the highest levels of venturi vacuum which can than be tapped to open the secondaries.
You most likely aren't going to be able to get them to open by just revving the motor in your garage to test it out. As stated by the previous poster the motor need sa load on it for them to operate properly so you need to check them by driving and feeling for when they open. Turn off the radio and try to listen carefully as you may be able to hear the change when they open.
The float arm is not bent. The floats, needles, seats etc are all new. I have adjusted the float so that no fuel comes out when I remove the little window screw. We'll see how it goes... last week it started flooding after about a hundred miles of driving.
What is the purpose of the needle/seat, movement?
