Vortec intake manifold
Old Sep 9, 2006 | 11:44 PM
Tankers's Avatar
Tankers
Default Vortec intake manifold
What manifold for the 350 vortec heads will fit under the 72 SB hood. According the the edelbrock website the perfomer for vortec heads will not fit.
Old Sep 10, 2006 | 02:51 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i don't beleive this...........every body worries about there intakes/carbs not fitting (including me) but the reality is very few of us have problems....do you due diligence but don't be surprised if others have no problems especially when they use drop base air filters
Old Sep 10, 2006 | 03:23 AM
Little Mouse's Avatar
Little Mouse
I'm not a vegas gambler type but I would bet money it will
go under your hood with a good drop base air cleaner I looked
up the height specs in my catalog it is just barely any taller
then the other performer manifolds.
Old Sep 10, 2006 | 09:31 AM
1972warship's Avatar
1972warship
I know Wiend has made a new one that will probably fit..
# Action +Plus Intake Manifold1996-Up w/Vortec (L31) heads
# Idle-5500 RPM
# Height: 3.375" front/4.5" rear
# Port size: 2" tall/1.06" wide
# Square flange carb mounting
925-8121
Here is a link http://www.holley.com/8121.asp
Of course if you want to run a qjet this will probably not help.
FYI: I have an edelbrock EPS which has a A-3.75 B-4.80 height. I'm running a 1 1/4 drop base and a 2.8 inch tall air cleaner...under a stock 72 hood.
The edelbrock specs are (as you know)
A-3.87", B-5.28"
Old Sep 10, 2006 | 10:22 AM
Tankers's Avatar
Tankers
# Idle-5500 RPM
925-8121
A-3.87", B-5.28"
Thanks guys, advice from the ones using the equipment is better than any manufacturers website. The weiand is the intake I will probably use.
Old Sep 10, 2006 | 04:00 PM
1972warship
just another fyi: here is a thread that talks about that intake versus the vortec performer...
http://www.chevelles.com/forums/showthread.php?t=95070
Old Sep 10, 2006 | 04:40 PM
Tankers's Avatar
Tankers
That was an outstanding thread about an intake, thanks.
To Vortec intake manifold
