My homemade ring compresser
Old Sep 11, 2006 | 12:01 PM
Durango_Boy's Avatar
Durango_Boy
Originally Posted by jackson
Stock sbc 400 bore = 4.125". FYI ... compared to thirty over pistons, there are relatively fewer offerings in twenty over ... MANY desirable shelf-stock sbc 400 pistons are not available in twenty over. Suggest do NOT assume that all pistons are available in twenty over ... but do your homework & all planning before you jump in.
Thanks for the info, but I have already had the motor back from the machine shop. Bored +.020 and decked. I then found and ordered a set of +.020 SpeedPro coated pistons. I then had them throw in the correct rings for a package purchase.
So a 400 being a stock bore of 4.125, I add .20, and need a compressor with a final bore of close to 4.145?
Old Sep 11, 2006 | 12:15 PM
jackson's Avatar
jackson
Yes. Purely a guess ... SP pistons either H615CP20 or H616CP20? Next time ... best to bore-hone block with pistons in-hand ... honed to fit individual piston. Same goes for rings ... hone/finish/grit/Ra to mfg's specific ring guideline.
Old Sep 11, 2006 | 12:17 PM
Durango_Boy
That was the original plan. I had dropped off the block to be bored +.030, and when I picked it up, the invoice said +.020. A called and asked what was up, and the machinist said they don't like to take more than is needed and the walls only needed that over-bore to be good again. Yes, I got a FULL refund, and then just decided to keep it the way it was.
Old Sep 11, 2006 | 12:30 PM
Hvymtlc5's Avatar
Hvymtlc5
Beats a tin can and hose clamps.
Old Sep 11, 2006 | 01:28 PM
Durango_Boy
What's wrong with tin cans? Beer cans are close enough. Somewhere I have this cool pic of an engine with an intake that had 8 tubes, six inches long, going straight up. I can't recall what that kind of old intake is called. Anyway, he had bottomlesss beer cans over the tubes, I guess to keep any rain or dirt from getting down into the intake.
Old Sep 11, 2006 | 05:56 PM
Twin_Turbo's Avatar
Twin_Turbo
Must be a stack injector with 8 ram tubes...search for enderle, hilborn, crower, kinsler, algon, engler, tecalmet-jackson,...you name it..
Old Sep 11, 2006 | 06:00 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I wish that I had your skill and tools!!
Old Sep 12, 2006 | 02:27 PM
Ratsirt's Avatar
Ratsirt
Nice Norval,
Glad to see your new addition is coming along well. Should be home in hopefully for Sept. 23 weekend will drop by if you are around.
