wheel weight v performance.
Old Sep 11, 2006 | 02:39 AM
hensen1954's Avatar
hensen1954
Default wheel weight v performance.
Anybody know of a site or article where I can read up about just how much wheel weight - or reduction via alloys, can help / improve performance ???
Regards,
Hugo
Old Sep 11, 2006 | 04:16 AM
73-84 IMSA Widebody's Avatar
73-84 IMSA Widebody
Not alot of help, but I just did a google search"wheel wieght performance" and 20 good reference sights came up. I may need to go back later and do some reading myself.
Old Sep 11, 2006 | 09:03 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Took over 100 lbs off my car by going with lightweight wheels and nylon ply tires and skinny front tires.. Got .3 better ET at the track...so, about 100 lbs rotating mass weight savings will feel like about 30 - 50 HP more power!
Old Sep 11, 2006 | 01:39 PM
aharte's Avatar
aharte
For straightline performance, lighter wheels and tires reduce the effective weight of your car. It is much more accurate to think of it this way than to say you gain effective power.
Anyway, they reduce your effective weight by their static weight plus the change in the moment of inertia divided by the square of their radius. In practice, this means that they effectively "weigh" 60-80% more than they would on a scale. So 100 lbs of wheels and tires might effectively take off ~180 lbs from a car. Being more precise would require knowing exactly how the weight is distributed throughout the tire and wheel.
Btw, GSC3 also has the lower rolling resistance of his front skinnies to help out. But that's only practical for a drag car.
Old Sep 11, 2006 | 04:54 PM
73-84 IMSA Widebody
I'm not sure what he said but I'll second it
Old Sep 11, 2006 | 05:12 PM
Wrencher's Avatar
Wrencher
I'm no engineer, but I know the rules! Less unsprung weight = GOOD!
Reducing the mass of the wheel/hub/caliper/upright assembly has multiple benefits, especially on a road course car. Has to do with forces in motion, inertia, total weight, etc....
Hans
Old Sep 12, 2006 | 02:53 AM
hensen1954's Avatar
hensen1954
Was thinking not only about the weight as a dead lump, but the fact that as 4 heavy items you are the proud owner of 4 gyroscopes. Any if you played with those things as a kid, you will know how hard they are to turn in certain directions when up to speed.............
Old Sep 12, 2006 | 03:18 AM
Graemeinvette's Avatar
Graemeinvette
Then here is your answer!
G
Old Sep 12, 2006 | 03:37 AM
aharte's Avatar
aharte
I don't know what gyroscopic effects could do in cars. I've never really seen them discussed, so I'd guess that they're negligible except perhaps to the finer details of the steering feel.
Old Sep 12, 2006 | 04:07 AM
hensen1954's Avatar
hensen1954
found something
http://www.torquecars.co.uk/Tuning/alloy-wheels.php
Old Sep 12, 2006 | 05:08 AM
Graemeinvette
Dont think so that only highlights the problems of different rolling radius wheel/tyre combo's. Nothing to do with the benefits of using lighter wheels.
G
Old Sep 12, 2006 | 07:36 AM
Star79's Avatar
Star79
Heavier wheels will also make all of your suspension parts wear out faster. A kid at work has heavy 18" steel chromies on his Civic and he goes through a lot of end-links, sway bar bushings, steering links etc.
Old Sep 12, 2006 | 05:48 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
So who makes a good 17"x8" lightweight rim?
Who makes the lightest rims?
Old Sep 12, 2006 | 07:36 PM
Guru_4_hire
Cruise-In V Veteran
What would be considered light
21 lb rim?
27 lb tire?
Old Sep 12, 2006 | 08:23 PM
hensen1954's Avatar
hensen1954
whats the weight of a steel wheel and factory normal tyre ??
Old Sep 12, 2006 | 09:10 PM
flynhi's Avatar
flynhi
A couple of years ago, I did the homewor on weights of a variety of wheels and tires.
Search the archives
To wheel weight v performance.
