Help!! Carb, fuel system issue?
Old Sep 11, 2006 | 10:15 AM
Daniel James23's Avatar
Daniel James23
Cruising
Default Help!! Carb, fuel system issue?
What a minute, this sounds all too familiar. I just purchased a 1973 vette, 350 automatic, and am having the same problems. After idling fine, heading up a hill or looking to hit the throttle, the car appears to bog out as if it no longer is getting gas. I had a mechanic replace the fuel pump, fuel lines, fuel filter, and even drain most of the gas. It appears that someting is clogging the line at different times, or... carb issues.
I have twice removed a rubber gas line to the carb, blown air through it back to the gas tank, reinstalled and then the engine runs great for the next few minutes, until eventually, I need that full horse power and it again, appears to bog out by not getting gas effectively and accurately. The only way I was able to get up a hill the other day was in reverse.
I have waited a long time to get a vette, and want to hit the road with it before the winter comes in a month. (Pittsburgh, PA).
Any ideas, sending unit, carb issue?
Much appreciated any help.
Old Sep 11, 2006 | 10:33 AM
noonie's Avatar
noonie
The next time it happens, undo the rubber line to your carb and put it into a milk jug and crank engine over. See if you get gas flow. If you do then put a pressure gauge on it and crank to test pump.
Gives you a plce to start.
Old Sep 11, 2006 | 10:40 AM
Daniel James23
Cruising
Default This helps
If the pressure is weak or non existant and gas is not flowing after cranking it over, then I presume the thought is that it may not be the carb, but the fuel pump (although I replaced this the other day), or maybe the fuel sending unit or something in the line?
I appreciate the help. New corvette owner and need to hit the road with it. If I knew how to send pictures, I would send one.
Old Sep 11, 2006 | 10:43 AM
olescarb's Avatar
olescarb
try driving the car with the gas cap loose or off, if the canister/gas tank vent system is plugged you can not get air into the gas tank to replace the fuel as the engine uses it. a fuel pump can not pump fuel from the tank if the tank has a vacuum in it.
henry @ oles carb
Old Sep 11, 2006 | 11:23 AM
justanotherdoe's Avatar
justanotherdoe
Check the power pump and float level on the carb.
Old Sep 11, 2006 | 01:37 PM
Daniel James23
Cruising
Dumb question from the novice. Power Pump?
Old Sep 11, 2006 | 02:00 PM
justanotherdoe
It is the plunger/piston in the carb that is part of the primary jet/rod control circuit (i've assumed you have a qjet?).
Here is a link:
http://www.corvettefever.com/howto/53360/
Old Sep 11, 2006 | 03:17 PM
MsVetteMan's Avatar
MsVetteMan
Adjust floats...........
Old Sep 11, 2006 | 03:58 PM
halfmoontrail's Avatar
halfmoontrail
What Henry Oles said about vapor lock...
or, the filter in the carb inlet is OFTEN overlooked, and they do plug. Should be a paper pleated filter, maybe a frit-type stone.
Steve
"power pump" sounds like accelerator pump, usually just limits hard acceleration if bad...should still be able to climb a hill.
Try the loosened or a vented cap.
Old Sep 11, 2006 | 09:31 PM
Daniel James23
Cruising
Ok, here was tonight's test and what to make of it.
After draining the gas tank to the best of my ability, I noticed some discolorization, maybe water, definately a little rusty in the gas tank.
So, I hook up a 1 gallon gas can at the wheel well directly to the fuel pump, and the car runs great. I did this about 6 times, finishing up a gallon of gas each time. No problems of course until I ran out of gas, which was rather quick. Accelerating, hills, hitting the throttle good. Runs great.
What is the problem then from the fuel pump back to the tank? Bad gas in the tank, rust, water? Time to drain the tank and clean it out? The "sock" looks good in the tank. I even clean it off some last time.
Or could there be another problem to consider?
Also, what kind of gas mileage can I expect from my 350 automatic? Seems like I was dropping a gallon of gas a lot quicker than normal. Which may be due to the goofy hook up of a gallon gas can on the wheel well.
Old Sep 11, 2006 | 11:14 PM
greyghost79's Avatar
greyghost79
J.P. Morgan used to say about yachts "If you have to ask you can't afford it". If yours is like mine, about 12 miles/gal. the kind of gas mileage the oil companies have wet dreams about. Happy driving.
Old Sep 12, 2006 | 01:22 PM
Brad_B's Avatar
Brad_B
I had a very similar problem a while back. My problem was the rubber hose from the tank to the hard line on the frame. The return and supply lines were crossed and the supply line was crimped. I dropped the tank and put new hoses on and it cleared up. Hope this helps. See thread below.
http://forums.corvetteforum.com/show....php?t=1322607
Old Sep 12, 2006 | 01:28 PM
Daniel James23
Cruising
Good point. I had the supply line changed though the other day. It was a real soft rubber and thought maybe it was squezzing shut. But, I did not check the return line. Only the supply line to the frame. What exactly is the role of the return line, where is this located in relation to the supply line? Could this create a vacuum problem?
Old Sep 12, 2006 | 01:44 PM
tracdogg2's Avatar
tracdogg2
There is also a filter on the pick-up tube inside the tank called the sock. Over time it breaks down and collapes over the inlet blocking flow.
Also check for the vapor cannister. If you have one and it is hooked up correctly you should use a non vented cap. If you don't have one either from the factory or has been removed and the hoses plugged you must use a vented cap.
Be sure you are using the molded fuel hose from the frame to the pump. Bulk hose often crimps.
Mike
Old Sep 12, 2006 | 02:02 PM
Daniel James23
Cruising
Mike
Yeah, I have checked out the sock, and it looks fine. I have a non vented cap. Thus I presume on my 73, it would have a vapor cannister as well. Where may that be found?
Old Sep 12, 2006 | 03:50 PM
tracdogg2's Avatar
tracdogg2
It's on the frame behind the drivers front wheel.
Mike
Old Sep 12, 2006 | 09:13 PM
airck's Avatar
airck
Man I love this forum! My 78 is doing the same thing, so thanks for posting and for all the suggestions. Mine starts, runs, idles and drives fine in town, but ask it to do more than that or take off from a dead stop with gusto and it sputters like a moped. I've yet to get it over 70, and man, it's a Corvette! I wanna GO!!
To Help!! Carb, fuel system issue?
