spark plugs
Old Sep 11, 2006 | 07:55 PM
Lilfur's Avatar
Lilfur
Default spark plugs
Has anyone tried the split fire plugs in a 1968 BB/ 427 ? If so how are the results?
Old Sep 11, 2006 | 09:00 PM
Sayfoo's Avatar
Sayfoo
If you use the correct heat range, I don't think you will notice any difference in any brand of spark plug in any thing short of a race car. Over the last 40 years, I've used most all major brands, and a few gimmic plugs also. I generally buy the ones on sale. A couple of months ago regular Autolite plugs were on sale for $.49 after rebate. They work fine.
Old Sep 11, 2006 | 09:02 PM
SmokinBBC's Avatar
SmokinBBC
I tried them in '70 350/350. I expected a performace gain, but didn't see any. My best experience is with platinum plugs.
I am currently using Autolite Platinum in my BB.
Old Sep 12, 2006 | 10:48 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I use the AC R43XLS on my big block but did try the SplitFire plugs on my 65 and I thought they were junk. The car seemed to lose low end torque. They were Ok at high RPM's but I didn't like the feeling of torque loss. Most mechanically inclined friends of mine agree that they are junk.
Old Sep 12, 2006 | 11:35 AM
442olds's Avatar
442olds
I use autolite 3924's, which are the counter part to the r43xls except that they use a 5/8 spark plug socket rathter than the 13/16. Makes it easier to get the plug in with the 2.25" header priamary tubes on my stahl side pipe headers. I'd rather use delco plugs but the guys at the autoparts store can't seem to figure out how to cross the 3924's to the delco plug with the 5/8 socket.
a plug is a plug, unless you get into the resistor and non resistor styles. You only get one spark (well if running msd after 3000 r's its only one spark) per ignition event so multiple ground straps don't really make sense to me. How are you going to get that spark to split, its going to head to the closest ground lug 9 times out of 10. and then you have the bosch +4, I have to ask WHY?! Platnium and the other High dollar plugs are just that high dollar. They may last a little longer but eventually they will break down too.
I change my plug alot more often than most people just because, so the cheap plugs are my preference.
To spark plugs
