buggered threads
Old Sep 12, 2006 | 09:46 PM
44bones's Avatar
44bones
2nd Gear
Default buggered threads
I have nicked the last 2 threads on one of my rear spindles, anyone know what size die and where I can find one? I think the size is 19M x 1.25, but all the precision places only list 18 and 20M dies. Goes on an 81. HELP! Thanks.
Old Sep 12, 2006 | 10:15 PM
SIXFOOTER's Avatar
SIXFOOTER
can you get a triangle file? I have used them many times to fix up hosed up threads on front spindles and the like
Old Sep 12, 2006 | 10:44 PM
...Roger...'s Avatar
...Roger...
Its 3/4- 20 but buy a set of thread files-you'll love em.
Old Sep 12, 2006 | 10:56 PM
...Roger...
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes this isnt the best pic but these come in fine thread,course and metric--Sixfooter http://store.summitracing.com/partde...5&autoview=sku youll like em.
Old Sep 12, 2006 | 11:10 PM
SIXFOOTER's Avatar
SIXFOOTER
Hmm, I have a set of jewelers files that usually gets the job done, but I have seen these. Might have to give it a try
p.s.
watchin for brown truck
Old Sep 13, 2006 | 12:01 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
You might be able to rent the die from a machine shop. The guy who pressed my T/As apart had one and used it to clean up my threads.
Old Sep 13, 2006 | 01:29 AM
jackson's Avatar
jackson
Good advice so far ... 'specially the thread file. I can't swear because I haven't measured every thread on a C3 ... but aside from the spark plugs & their holes in heads, I doubt you'll find too many metric threads on C3.
Old Sep 13, 2006 | 06:47 AM
...Roger...
Another way in a pinch is to -cut a nut in half-wrap nut around threads below damaged threads and clamp with vicegrips-now unscrew over bad threads-do it several times.Cheap split die.
Old Sep 13, 2006 | 08:08 AM
SIXFOOTER's Avatar
SIXFOOTER
My 81 has several metric bolts on it, very confusing
Old Sep 13, 2006 | 05:55 PM
Durango_Boy's Avatar
Durango_Boy
It must have been repaired at some point at a Mitsubishi shop...
Old Sep 13, 2006 | 06:50 PM
GTR1999's Avatar
GTR1999
3/4 -20 is correct. If the spindle is out then try a carefully dress it with a file until you can screw an old nut on it. Then use some AAA cloverleaf lapping compound and work the nut on to clean up the threads. Fit a new nut when you're done and throw out the old one.
You can buy a die from McMaster-carr too if you want.
Old Sep 13, 2006 | 09:13 PM
Durango_Boy
What is that? Where can you get it and what all is it good for?
To buggered threads
