Carb Question
Old Sep 12, 2006 | 11:08 PM
724544SPD's Avatar
724544SPD
Default Carb Question
I need to find a mechanical secondary Q-jet for my 72 BB 4-speed car. I will likely break down at some point and pay major $ for the correct carb.
In the meantime, I am interested to know if anyone is aware of other GM cars/trucks that would have had a comparable carb.
My thought is that I would run the non-correct carb on the car and set the major $ correct carb aside.
Old Sep 13, 2006 | 12:06 AM
BigBlockk's Avatar
BigBlockk
I don't know... going to be tough to find a mechanical secondary Quadrajet. They only made about a hundred million of them. ALL Quadrajets are mechanical secondary carburetors.
BigBlockk
Later.....
Old Sep 13, 2006 | 12:18 PM
lars's Avatar
lars
BigBlockk is correct - All Q-Jets are mech sec carbs.
Your 72 setup, if you want to keep you choke system operable and correct, has the limitation that you need to find a '68 through '74 Chevy Q-Jet. You can use any car or truck Q-Jet in this year range, with the '70-74 being the most versatile and reliable. These will interface with our choke linkage and throttle linkage without problem. Find a carb that has not been commercially rebuilt (commercial rebuilt carbs are real junk). Go through it and set it up to its stock correct jetting specs. It will run great.
Old Sep 13, 2006 | 02:29 PM
justanotherdoe's Avatar
justanotherdoe
Keep an eye on eBay. I was able to find a carb with the correct date code for my 76 in roughly 2 months. It was in good shape and a rebuild based on lars' papers and a kit from oreilly's has it running beautifully.
To Carb Question
