solid T-arm bushings
Old Sep 14, 2006 | 10:53 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Default solid T-arm bushings
I have a set of brand new solid T-arm bushings that I'm not going to use.
I've had them for about 15 years, I believe they were made by Herb Adams VSE, I want to sell them but I don't know what they're worth.
anybody have any ideas?
I'll post pics in a few...................
Old Sep 14, 2006 | 11:06 AM
Twin_Turbo's Avatar
Twin_Turbo
Are they spherical joints as in a milled down metal ball in a metal sleeve or a johnny bushing, a metal ball in a urethan or teflon sleeve? Why not use them, those things are THE answer to bind free trailing arm bushings, so much better than the stock deal.
Old Sep 14, 2006 | 11:08 AM
RPOZ4Z's Avatar
RPOZ4Z
Here is a pic...........
I guess they are spherical?
the center rotates inside the outer sleeve.
the need to be welded in.
Old Sep 14, 2006 | 11:42 AM
redvetracr's Avatar
redvetracr
I am interested!! figure out a price and let me know!! redvetracr@msn.com
Old Sep 14, 2006 | 01:33 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
And people say not to use poly in that spot because it doesn't have any "give" ...
Old Sep 14, 2006 | 01:53 PM
Twin_Turbo's Avatar
Twin_Turbo
you are missing the point, poly does not like the side loading that happens there, that bushing does not just rotate, as the suspension moves the toe changes and this results in that bushing deflecting, the above being a spherica bearing it will not bind like a urethane bushing (a rubber one has sufficient " give" but offer butter smooth bind free movement of the trailing arm. Why do you think redvetracr is interested? He knows what is good stuff and what's not..I'm willing to bet he doesn't have poly bushigns in that spot.
Old Sep 14, 2006 | 02:08 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
With 'smart struts' or lowered strut rod bracket the trailing arm rotation and camber change should be eliminated, at least minimized...... then poly is ok.... correct ???
Old Sep 14, 2006 | 02:17 PM
Twin_Turbo's Avatar
Twin_Turbo
not camber, TOE. Toe is the result of the triangular arrangement that the trailing arm, hub, halfshaft/strut rod and the frame attaching points and tghe stub axles make. As the suspension moves the angle that the trailing arm makes with the car axis changes, this is the toe. The toe is at it's largest when the halfshaft is parallel with the ground and less in all other positions above or below that. Now think this through with a rigid bushing in the front like a poly bushing.
Old Sep 14, 2006 | 02:25 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I'm having a hard time seeing how the toe is changing during susp. travel.... with the stock strut rods yes, the camber and toe changes but if you lower the strut rods so that they're parallel with the half shafts the camber and toe shouldn't change ??? what am I missing ?
Old Sep 14, 2006 | 02:44 PM
Twin_Turbo's Avatar
Twin_Turbo
it has nothing to do with strut rods being parallel, it has everything to do with the halfshaft angle. Do you know how vectors work? A vector has 3 components, but we'll only look in a 2D situation so it has 2. A horizontal and a vertical component. The 2 components are changing as the vector angle chagned but the vector length always remains the same. So, now the halfshaft is sort of a vector. It has it's largest horizontal vector component when it's parallel to the ground (being the full halfshaft length), the vertical component is 0 in that case. In ANY other suspension position the horizontal component is less than max (halfshaft length). This is the angular effect of the suspension movement. Now, the trailing arm angle with the car axis (the toe) is dependant on the horizontal halfshaft componenet. As this changes so does the TOE and the bushing deflects.
Old Sep 14, 2006 | 02:56 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Makes more sense now.....
What about upper strut rods ? I was planning on installing these and lower the lower strut rods. The clips that hold the side yokes are already gone so my yokes move in/out as the suspension moves...
Does the toe still change with the sliding half shafts/yokes ??
Old Sep 14, 2006 | 03:12 PM
Twin_Turbo's Avatar
Twin_Turbo
those struts all control camber, none of them control toe, that's only done by the trailing arm and halfshaft. If your yokes/halfshafts slide then yes, the toe changes..and thats NOT a good thing.
Here's a little drawing, see the dotted lines? The angle of the trailing arm is the toe. This is seen direct from above, now imagine the suspension moving...the halfshaft will get " shorter" in this view as it angles down or up. The hub will get " closer' to the differential in the horizontal plane and the angle of the trailing arm becomes less.
The ONLY way to fix this is to use tierh double a arms or a 5 bar/c4 type suspension with sectioned trailing rods (you'll need 2 to make up a rifid arm that controls bearing hub yaw/roll and they can be set up to have a virtual swing arm length by their virtual intersecting point), this way the trailing rods only position the wheel fore/aft and do not control toe as they have 2 gine points (where the trailing arm only has 1 and is rigidly attached to the bearing block), then you'll need a toe control setup or 2 lower camber rods w/ toe control set by the relative settings of these 2 (per side) that's how guldstrand did it.
Old Sep 15, 2006 | 08:10 AM
RPOZ4Z's Avatar
RPOZ4Z
that's the reason I bought them for my '77, back then, I was trying to improve the performance of the car, I also installed a VB&P front transverse leaf spring kit on it, with their upper control arms, my priorities were different then, the '77 was my daily driver and I wanted it to handle as best it could.
now for the '73, I'm not sure if it's worth me using them on a car that's not going to be driven much. plus I have the '98 for performance and handling!
Old Sep 15, 2006 | 08:57 AM
1970-Bronze's Avatar
1970-Bronze
So why don't you see this more often then as the replacement?
Old Sep 15, 2006 | 09:18 AM
RPOZ4Z's Avatar
RPOZ4Z
maybe because of the way they have to be installed?
Old Sep 15, 2006 | 09:50 AM
norvalwilhelm's Avatar
norvalwilhelm
I have smart struts both top and bottom or better known as a 6 link and I did alot of testing for TOE and it was terrible. While camber stays the same the toe change is rediculous.
Twin turbo address this with his new free floating hubs
Old Sep 15, 2006 | 10:04 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
TT and I had a few PMs about the toe... now it's crystal clear :o
I'll still go ahead and install my upper strut rods and copy Brutus' "poor man's 6-link". I'll have to live with the toe change but I don't race the car so I guess I'll be fine
To solid T-arm bushings
Old Sep 15, 2006 | 11:49 AM
norvalwilhelm
I really like the 6 link for a number of reasons. First the yokes are now totally free floating. I grind the end of the yoke off from the clip to the end that would normally bump on the pin, This makes for no wear and deposits in the oil.
The 1/2 shafts are no longer part of the suspension and only transmit power.
Finally with the upper rod in place the side loading or twisting motion on the trail arm is gone. The upper and lower strut rod take all the twist out of the trailing arm and this really is important with coilovers that would normally load the trailing arm on one side only.
Brutus did a great job but BUT the upper strut rod is attached to a bracket that is bolted to the rearend cover that is bolted to the cross member.
Why make the bracket in the first place just to bolt it to something that is bolted to something else.
Why not just put a stud directly on the crossmember and slip the rod end over this to make a more rigid inner mount???
This method is alot simpler, more rigid and easy to do.
Weld a stud on the crossmember and forget an elaborate bracket.
Old Sep 15, 2006 | 11:54 AM
norvalwilhelm
This is a poor picture taken years ago of the upper link on a stud
Location is important
Twin_Turbo's Avatar
Twin_Turbo
Make damn sure your upper rods are compliant with the lowers AND the halfshaft when it comes to geometry, hinge points and sharing the same instantaneous center. If you don't do this your stub axle may move in and out of the diff an excessive amount. Get it spot on and it won't move at all.
Norval, do you have everything parallel, no camber change?? Do the rod ends and u joints all line up? (as in draw a line through the outer 2 rod ends and it should intersect the hub side u joint, same for the inboard set)???
