Need help! Electrical Problem Phase 2
Durango-you could be right-I could fill a book on this alarm system and what happens to it- and what it does to other things-when its not wired correct.
Considering all the threads full of problems related to these alarms, someone with intimate knowledge of it all should write a paper that can be cited whenever soemone needs a source.
Any findings to post? With more clues or things you rule out we can come up with different options or places to look.
The rear window defroster now works, which had not worked since I had purchased the car.
The problems I have now are:
1) The horn and alarm do not work.
2) The engine does not idle correctly, once it warms up it shoots up to 2000 rpm, after in runs for abut 1/2 hour it will drop back down. The choke light is always eluminated.
3) The electric seat does not function.
At least the car is drivable, but with the seat in the wrong position, and the choke always engaged (I think), it is not as much fun as normal.
I still am wondering why all of this stuff went astray at the same time?
#2 - Is your choke a manual choke or an electric choke? It seems that whatever signal your car gets from the engine or exhaust to adjust choke is not working. Maybe a censor or something is failing. If it's a manual choke, check to make sure it adjusts as the engine warms up.
#3 - Pull the seat out. Test the plug at the seat to make sure it has power and ground. Then, use a car battery and testt eh seat motors to make sure they work. Then double check it's fuse again, sicne they can appear good and still be blown. Always better to replace with a enw one just to be sure. If the fuse is good, and the motor works, then it falls back ont he wiring to the seat. You should have 12V constant to the seat, if at elast with the ign on. If you have NO 12V ever, trace the wire and see where it goes. If nothing else, run your own power wire to the motor to make it adjustable until you can find the real problem.
The problem with checking the fuse is I am not sure which fuse operates the seat. None are labled for it. I have replaced most of the fuses, but I can easily replace them all. Just have to go buy one of those large metal cased fuses, that is what is marked pwr accy, but that is the only accesory that is not functioning, and the fuse did check out ok with the continuity check.
Hmm...okay, well do some checking on that seat wire, and fuses. I'm just throwing out ideas based on what I've found to be wrong before. A blown fuse that looked great.
The Choke fuse may be bad, it is the top fuse on the right, 20 amp, labled C/H.
The choke light gets power all the time from the gauge fuse, 20 amp center left, and a ground from either a bad alternator, or thru the chike relay and the choke heater. If the choke heater fuse opens, it drops out the choke relay and the NC contact gives the light a ground thru the choke heater.
I had dash lights go out it was the grounded
What year did they start putting them back there?
The normal (front) horn relay is under the hood
Saves you from pulling the seat if there is no power there.
The power seat harness gets power from under the center console, actually under the parking brake cover where it plugs into another connector that is part of a main wiring harness.
I added a power seat to my 81 so that is how I know this circuit.
Coming off the positive battery cable at the starter are two fuseable links. One of these links splits into two; one goes to the single wire output terminal of the alternator, the other goes to the two terminal connector that plugs into the alternator.
The other one goes to the headlight switch and then onto the gauges and so on.
Good luck
