my car will not slip out of first gear until rpms are ridiculously high that was going on for a couple days. and now it feels like the tranny keeps slipping and the engine just cant connect with it...so on the way back to my house there was smoke pouring out the back of the car and the engine stayed ideling high because today it just would not shift outta first. it also feels like the tranny keeps slipping the engine catches it barely at times.
the engine is fairly new its an overhauled 327 its got a 350 cam but not pushing too much horsepower maybe around 250hp . the tranny i am unsure if it was the original or not...but what do u think my issue is and whats the cost for trannys and or converters?? WWUD??
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
sounds like the torque converter to me.....if the engine is revving high and it seems like its not connecting to the trans it may not be....i'm not sure what the smoke is unless you burst a trans line and its shooting onto the exhaust .....i bet this would also cause the trans to operate goofy
Sounds like the diaphram in the modulator is blown. Crawl under the car and unhook the vacuum line going to the modulator(pass side of trans). If there is fluid in it, replace it. That should solve the problem
1 more vote for modulator. When it fails the trans relys on the govenor for shifts and they can be very high. Also if the diaphram has a hole you will get smoke as the motor takes in the trans fluid.
can u explain more in depth about the modulator and what i should be checking or replacing exactly? how would the good part look as opposed to one that was blown...
The vacuum modulater senses engine load by the vacuum signal. A rubber diaphram inside the modulater reacts to this vacuum and in doing so moves a valve within the transmission valve body, allowing it to shift into second or third. If the diaphram was torn, it can't move, thus it won't shift. Instead of pulling on the diaphram, transmission fluid will instead be sucked into the engine, creating the smokescreen you see blowing out behind you.
To check this, just pull the vacuum hose hose off at the modulater, if transmission fluid comes out, that's your problem. You may even want to test it for vacuum also if you don't see any fluid, just to cover your bases.
If you have to remove the modulater, drain the trans fluid first and remove the U-shaped clip holding it in place, and pull it out. You should be able to buy one at the local parts store for around $15.
Good luck, let us know how it goes
cool info thansk for the steps... some of u guys just know way too much SHYT
but thanks im new to vettes, in my early twenties and have worked on imports most of my life..figured id get into american muscle but i mean these vettes have LOTS of problems, yes the car is 30+ years old but DAMn
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Ya, the imports have lots of problems too, they are ugly and sound like shi!
