Run for the hills - another D port/header question
Old Sep 17, 2006 | 10:45 PM
surfshark's Avatar
surfshark
Default Run for the hills - another D port/header question
With regard to D port exhausts and headers such as those made by Hedman- are there any differences in GM aluminum heads and header fitment from the Fast Burn, Edelbrock Etec, Brodix heads,, etc. or any early D port heads?
One of my dad's friends is selling a set of early Aluminum heads #14011049 (not sure if they're Phase 6 though) for $600. I mated my standard flange headers to them at the races last night and they look close, but I'm not sure if I'll get a good exhaust seal. Any words of wisdom out there on early D port heads?
Finally, it looks like they are 55cc chamber heads and I'm considering having a friend or machine shop open them to about 64cc or so. Any experience out there with this as well. Thanks as always for any advice.
Old Sep 18, 2006 | 12:59 PM
Lt1er's Avatar
Lt1er
For all the bigger exhaust port heads you need the larger 1 3/4 primary pipes.
The"D" port bottom lip acts as an antireversion device. FelPro blue steel impregnated gaskets with exhaust head studs is the only way to go.
