New Floor Pans?
Old Sep 16, 2006 | 07:32 PM
X Man's Avatar
X Man
Default New Floor Pans?
Hi All
The time has come to replace the floor pans in my 80 Vette.
My wife got in the car today and her heel went through the
floor.....Not Good
Where would be the best place to buy new ones? I see Corvette
Central has them for $259.95 each.
Could I replace them myself in the garage or is this a job for the
body shop?
Barry
Old Sep 16, 2006 | 07:56 PM
bruced267's Avatar
bruced267
I have looked in all the mags they are all the same price I guess its all who you like the best. This will be my inter project, the front is rivited to fire wall , no problem there . If you hve mig welder the rest shouldnt be to bad either, when you cut the old floor out make sure you leave yourself a lip to weld to. If you dont have a welder they make panel bonder rated for like 5000 psi they use this in body shops today for major repairs , however they still weld a small amount . also seam sealer top and bottom would seal up the repair nicely.
Old Sep 16, 2006 | 08:37 PM
Duke94's Avatar
Duke94
I would take it to a body shop and have them install it. It's not a job for the novice.
Old Sep 16, 2006 | 08:44 PM
Bob Onit's Avatar
Bob Onit
Not a big jog
DR rebuild has quality pans
A drill and rivits/bolts will work fine
I did my drivers side a while ago....... no big deal.
Old Sep 16, 2006 | 08:52 PM
bruced267's Avatar
bruced267
Old Sep 17, 2006 | 02:16 AM
Star79's Avatar
Star79
You can do it yourself, I did both of mine with panel-adhesive + rivets. Try to find a set of pans cut out of another car, they'll fit better than the reproduction ones. I got mine on ebay after searching for a couple of months. A shop will charge you a FORTUNE to do this job.
Old Sep 17, 2006 | 09:26 AM
X Man's Avatar
X Man
I think I'll give it a try myself, I have a mig welder
and all winter to work on it. Only thing is
by the time I get the pans delivered they will be about
$300.00 each. That is a lot of money
Old Sep 17, 2006 | 09:45 AM
Corz's Avatar
Corz
Cruise-In IV Veteran
check this out..
http://www.autobodysupply.net/duramixmetalbond.htm
its called duramix, its an epoxy stronger then most welds.
Old Sep 17, 2006 | 04:02 PM
X Man's Avatar
X Man
Corz..........Thats Cool
Old Sep 17, 2006 | 04:24 PM
Bob Onit's Avatar
Bob Onit
Maybe you would like to tell us what year your car is so someone could possibly locate pans at a less expensive price?
Old Sep 17, 2006 | 04:28 PM
Kenzy's Avatar
Kenzy
Hi All
floor.....Not Good
Barry
HTH
Old Sep 17, 2006 | 07:44 PM
Bob Onit's Avatar
Bob Onit
Originally Posted by Kenzy
HTH
Whoops
My apoligies
To New Floor Pans?
