Tachometer doesn't work?
Old Sep 18, 2006 | 02:18 PM
Augustus's Avatar
Augustus
Default Tachometer doesn't work?
I was coming home from a drive and while parking it the garage I noticed the Tach wasn't moving...
I have the stock Distributor with the Petronix system in the Distributor with the Petronix Coil.
What do I check for?
Anyone?
Old Sep 18, 2006 | 02:42 PM
Graemeinvette's Avatar
Graemeinvette
Cable drive or electronic?
Old Sep 18, 2006 | 02:50 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Tach cable, tach drive gear, distributor main shaft. If the cable is okay and connected correctly, you have possibly chewed the teeth off the drive gear. When those go, they usually take the teeth on the shaft with them.
Old Sep 18, 2006 | 05:31 PM
Augustus's Avatar
Augustus
OMG!! I hope the Tach Cable hasn't chewed off the drive gear.
So I'll cross my fingers and hope the cable is bad and not the drive gear..
Where would I get another Tach Cable or distributor? LOL
Old Sep 18, 2006 | 05:53 PM
694speed350's Avatar
694speed350
From what i have read it's proably the main shaft of the dist. the gears that mesh get damaged and when they do both need to be replaced. you can check operation of the tach by disconnecting the cable at the dist. and spinning the cable by hand or with a drill to check the tack and cable.
Old Sep 18, 2006 | 06:05 PM
Augustus's Avatar
Augustus
That's Great.. That's Just Great!!!! LOL Mo Money!! LOL
694speed350 Thanks for your reply and I'll try that by hand...
*Now where would I get another Dist and Tach Cable?
Who sells them? Year one or something?
I just did my motor and put a Petronix Ignition in the original distributor to keep the stock appearance... Now I might have to fix the Tach/Distributor Arrghhh
Old Sep 18, 2006 | 08:53 PM
Mike Mercury's Avatar
Mike Mercury
you can get your tach converted to electronic operation (while still using your original dialface & pointer for a stealth upgrade).
Email me if you'd like more info:
tim-yvonne@juno.com
Old Sep 18, 2006 | 09:53 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
It's usually the cable especially if yours takes the 90 deg bend off the dist.
http://forums.corvetteforum.com/show....php?t=1499948
Old Dec 17, 2006 | 03:44 PM
carnutbob's Avatar
carnutbob
Default can't solve mech. tach problem
Augustus,
Just curious if you solved your problem. I have the same problem with my mechanical tach on my '69. I can attach a drill to the distributor end and make the gauge function, but when it's all hooked up it doesn't work. I bought a new cable and took the gear out of the distributor (looks good) adjusted the end play of that gear and still no needle movement. I can hook the cable to the distributor and it turns too. Any ideas guys?
Old Dec 18, 2006 | 01:29 AM
TimAT's Avatar
TimAT
Try putting the dist gear on the cable and then turning it. It's possible the cable side of the gear is no longer square. Sounds like you've checked the cable, looked at the gear, ran the tach with a drill, so look at what's left.
Old Dec 26, 2006 | 08:03 PM
carnutbob's Avatar
carnutbob
Default I repositioned distributor and now tach is working!
I read about positioning the distributor so that the vacuum can points to the passenger side of the car. I did that and now the tach works. I am guessing that there was too much of a bind in the cable and/or that there is just enough give in the gears inside the distributor housing that they weren't meshing. Or maybe there is some slippage somewhere to prevent the cable from breaking. Anyway, it also makes getting the cable on and off the distributor much,much easier. Mine was mashing into the firewall. I can't wait to drive it and see how much rpms I have at different speeds. I put this car together from a basket cast, and this summer is the first time it's moved under it's own power in 20 years.
Old Dec 26, 2006 | 08:12 PM
74vette454's Avatar
74vette454
on my 454 my tach doesnt work and its electric... any ideas where to start?
Old Dec 26, 2006 | 10:16 PM
lars's Avatar
lars
Augustus -
You might want to check out this thread:
http://forums.corvetteforum.com/show...highlight=lars
I talk a bit about how the crossgear locks up and how you need to have it fixed.
To Tachometer doesn't work?
