Yes, you can't remove the rotor unless the rivets are drilled out. I would center punch the rivet and then drill with a small bit. Increase the size of the bit until the entire rivet has been removed. In addition, mark the position of the rotor, relative to a specific position on the axle stub. I marked a lug with a spot of paint and a corresponding dab of it on the rotor. That way, you can replace the rotor in the original position. That should give you the best chance for having a balanced rotor and axle assembly.
The reason hey are rivited in the first place is because the frame is upside down when they get installed on the frame, when it gets flipped over the rotors would fall off.
I think I also saw somewhere in here that the rotors were trued on the hub, which would mean they have to stay together and same orientation to keep from losing setup
you planning on the wheel falling off? rotor can't go anywhere with the wheel in place. even with the wheel off the caliper holds it on the rotor, albeit loosely.
Cruise-In IV Veteran
Cruise-In V Veteran
Here's how Vette wheels work:
As the rotor is pressed into place, the center of the wheel contacts and fits tightly on the center of the hub. All weight of the car on each wheel is born by the hub at its center. The lugs and lug nuts just keep the rotor held firmly against the hub. The lugs themselves are not load bearing.
Note: if you purchase an incorrect wheel that does not fit the hub correctly, then the weight is placed on the lugs. Somewhere along the line your wheel will fall off...
There are a lot of people running lug-centric aluminum wheels on C3s. That said, this is the exact reason why I'm upgrading to 1/2" studs.
Well this has been discussed here many times but this is how I do them. It takes more time but it's a better job. Dan is correct the runout is the issue. I've measured the runout by just bolting the rotors on with the lug nuts and it changes everytime. Sometimes by only a few thousands other times much more.
The hubs and spindles were riveted then faced so the brake surface is perpendicular to the spindle center and runout in under .001"
If you have a lathe larger then 12" then you can do this with the rears, the fronts can be done on a properly setup brake lathe.
I prefer to bolt them on then shim to correct the runout and be done with them. If you break the flat heads loose then you'll have to recheck the runout.
Here's my car with 300 miles on them.Runout was set to .002" Endplay at .0015-.002" Brakes work great- no O rings.
