relays for headlights
Old Sep 19, 2006 | 09:19 AM
docmag's Avatar
docmag
2nd Gear
Default relays for headlights
I've upgraded my headlights to halogen and would like to take some of the load off the electrical system. Putting relays in would help. What color wires supply the headlights(high and low) on a 78 vette? TIA Pete
Old Sep 19, 2006 | 10:04 AM
sly vette's Avatar
sly vette
I think its green for high and tan for low. Check them with a circuit tester.
Old Sep 19, 2006 | 10:52 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
This is one of those times when we recommend buying shop manuals...
Old Sep 19, 2006 | 11:03 AM
norvalwilhelm's Avatar
norvalwilhelm
Anyone attempting this should have a little electrical knowledge and if you posses this knowledge a quick test with a multi meter will quickly reveal which is which.
Old Sep 19, 2006 | 11:33 AM
SIXFOOTER's Avatar
SIXFOOTER
use this diagram, one of the best I have found, saved me from having to do it myself.
Old Sep 19, 2006 | 11:48 AM
VetteNut72's Avatar
VetteNut72
Light green for high and tan for low .
There is a harness available from Speed Direct, a forum sponsor, that will upgrade the headlamp system to relay control. It is completely plug-n-play and requires absolutely no modifications to your present wiring.
Speed Direct SK NeverNights Harness
They are designed and manufactured by a Corvette Forum member who loves C3's as much as we all do and is proud to provide a quality product to the Corvette resto/mod community .
Craig
Old Sep 19, 2006 | 03:10 PM
docmag's Avatar
docmag
2nd Gear
Sixfooter, Great diagram, THANK YOU!!! Pete
Vettenut, Thanks for the link but at 220.00 I think I can "splice" them in correctly. Again appreciate the info. Pete
Old Sep 19, 2006 | 08:01 PM
pws69's Avatar
pws69
Great drawing, Six! Looks like Don Olson's work!
Last one I did (Jeep with 150W H4's), I did it on the fly - took a while! This will save time when I do the 'vette.
Thanks!
Old Sep 19, 2006 | 08:41 PM
shafrs3's Avatar
shafrs3
Craig
I bought this harness and lights. The high beams won't fit without really hacking the headlight buckets. The rest of the product is top notch.
Old Sep 20, 2006 | 09:39 AM
VetteNut72's Avatar
VetteNut72
The lamps are added by the distributor
and the harness is built by the forum member. He thanks you for your support of this quality product
Craig
To relays for headlights
