Trans Fluid/Filter replace
Old Sep 20, 2006 | 08:41 AM
Darrel1's Avatar
Darrel1
Default Trans Fluid/Filter replace
1980 L48 TH350 Auto trans 50K miles
I just removed the trans pan to replace filter and fluid. I have a couple of questions
1. While I have the pan off is there anything I should look for or replace?
2. I suspect the previous owner had not changed the fluid in sometime. It was very brown but did not smell like it was burnt- just very dirty. Is this an indication of anything other than it has not been changed in a long time?
3. The gasket that came with the filter is cork. Any tricks when I put the pan back together? Is cork ok or is there a better gasket I should use?
Thanks for any advice.....
Darrel1
Old Sep 20, 2006 | 08:54 AM
Wuttin's Avatar
Wuttin
Cork is fine, just be sure to torque to spec and not give into the urge to overtighten...I think it is 12 ft-lbs but check the book. Also you may want to write down the trans number that's on the casing right above where the linkage connects on the driver side...easy to see now, hard to see when reassembled. Just keep it on file for when you recover the buildsheet for comparison.
Good luck
Old Sep 20, 2006 | 01:10 PM
Darrel1's Avatar
Darrel1
Thanks, I never thought of that. I pulled my gas tank last month due to a leak and I have my build sheet. Should I change the modulator now? I do not think it is bad (I have to look into the rubber hose to see if there is fluid). I am not sure if modulators go bad periodically and better to do it now when the pan is off.
Darrel
Old Sep 20, 2006 | 03:43 PM
halfmoontrail's Avatar
halfmoontrail
Modulators go bad rarely, but probably is worth the money to change now as you are under there, and the fluid is out.
Steve
Old Sep 20, 2006 | 04:40 PM
1980 blue L48's Avatar
1980 blue L48
My 80 has a 350c lock up convertor, I just put in a B&M shift kit. set for street/strip. After 79k miles, fluid looked great. It will now get a little rubber when it hits second gear. Its all stock 3.08 gear, 190 HP. It did need a modulator, it had fluid in it.
To Trans Fluid/Filter replace
