TH350 Rebuild Costs?
Old Sep 20, 2006 | 11:57 AM
kursed56's Avatar
kursed56
Default TH350 Rebuild Costs?
Okay, my tranny just grenaded and Im getting a range of costs to rebuild it. From $400 to $1200 to remove it, rebuild and replace. Its in a 1980 Vette.
Im guessing that all TH350's are same across the board. Or are the Corvette models different?
Or just wait till I get some cash and do a 200R4.
Old Sep 20, 2006 | 12:12 PM
wnmech's Avatar
wnmech
I have never had a turbo 350 rebuilt but if they are going to remove overhaul and reinstall the transmission and give you some kind of a warranty for max of $1200 it dont sound unreasonable to me. Some of the 350's have the lock up convertor installed but other than that I think they are pretty much all the same.
Old Sep 20, 2006 | 12:18 PM
BONESTK87's Avatar
BONESTK87
Default tranny
i just paid $300 to have mine rebuilt, $200 for parts including a new torque convertor and $100 labor. but i pulled it out myself. mine is a turbo 400. the turbo 350's and 400's are about the same price to rebuild. i think all turbo 350's are the same except for the lock up convertor like (WNMECH) said which kinda makes it a overdrive trans and the long tail and short tail tailhousings: I think $1200 is a bit high for a turbo 350 even if they are going to R&R it ang give a warrenty.
Old Sep 20, 2006 | 12:30 PM
MartyW's Avatar
MartyW
I had my TCI TH350 rebuilt a few months back and the total was $1300 for everything. That was just driving the car down to them and having them do everything. This was also for all heavy-duty parts for the rebuild.
EDIT: The $1300 did include a full rebuild of the torque converter as well.
Old Sep 20, 2006 | 01:08 PM
gyopp's Avatar
gyopp
I spent $800 to have mine rebuilt w/ shift kit, heavy drum & sprague, extra clutch, etc. That did not include torque converter or install. To have it done $1200 don't sound bad. If you are wanting a 2004R there is no time like the present. Don't spend $1200 doing something you are not happy with.
Old Sep 20, 2006 | 01:16 PM
criss80's Avatar
criss80
Navigator
Bones,
Where did you get it rebuilt?
My TH350 is leaking from the detent cable, and I will replace the o-ring/seal but otherwise have been thinking of pulling it out and getting it locally rebuilt. I'm in the plano area.
Criss
Old Sep 20, 2006 | 01:25 PM
bams12's Avatar
bams12
How much would it cost to swap the TH350 for the 2004R ?
Old Sep 20, 2006 | 01:43 PM
kursed56's Avatar
kursed56
Thanks guys. Im guessing that to replace the 350 with the 200 would cost about the same.
Yes, the $1200 includes removal, rebuild, installl and warranty.
Ill have to ask about a shift kit and any other performance mods.
Old Sep 20, 2006 | 02:08 PM
MartyW's Avatar
MartyW
Don't let them rebuild it with 1/2" bushings. Make sure that they use 1" bushings when rebuilding. Even from TCI the TH350 only had the 1/2" bushings and mine were absolutely shredded when they took apart the transmission. The shop rebuilt it using 1" bushings.
Old Sep 20, 2006 | 02:40 PM
kursed56's Avatar
kursed56
Marty and others, are you all happy with your TH350's? Or should I be thinking about the 200R4?
Old Sep 20, 2006 | 02:43 PM
MartyW's Avatar
MartyW
My car is not a highway cruiser so I absolutely love the TH350 I have in combination with my 4:11 rear gears. I would not change a thing. Mine is a bit unique with the reverse pattern shifter and all manual valve bodies. Gives me the best of both worlds.
Old Sep 20, 2006 | 02:53 PM
SIXFOOTER's Avatar
SIXFOOTER
There is a guy here in Hollywood Fla selling a built 2004r for about $1k
Old Sep 20, 2006 | 04:31 PM
wnmech's Avatar
wnmech
Originally Posted by criss80
Bones,
Criss
Hey criss that detent cable o ring can be replaced with the tranny in the car. It is only one bolt and you pull the cable out of the transmission and there is kind of a hooked deal that goes into the valve body it will slide right out and replace the o ring and its a piece of cake. wont cost much more that fluid and time that is if your transmission is good other than the leak.
Old Sep 21, 2006 | 12:02 AM
682XLR8's Avatar
682XLR8
kursed56-Save some $$$ and go for the BTO 200R4
Mine was a little over $1800, but that included shipping, tax, all the other gadgets that go with it. All I had to buy was a new U-joint and fluid
Old Sep 21, 2006 | 12:15 AM
happiedazs's Avatar
happiedazs
What's a 200R4. I'd love to replace my 3 forward speed trany with a 4 or 5 forward speed trany if it's an easy swap without lots of modifications and jury-rigs.
Old Sep 21, 2006 | 11:44 AM
MonzaRedConvert's Avatar
MonzaRedConvert
Hey Sixfooter, who is that? Can he rebuild my TH400? I've been looking for a reputable transmission guy in this area.
To TH350 Rebuild Costs?
