Considering wheels that require adapters...problems drag racing?
I'm considering a 17" rim/tire that will require adapters (bolt to the rotor then wheel bolts to adapter). Assuming I will have over 500 hp (new engine/trans in the works) can they be used in constant track drag racing and what's the max spacing I can get away with? Thanks!
I tore up alot of rear end stuff over the years. I was very lucky to always be able to shut things down fast enough to avoid body or structural damage
I used to run 3500 stall and 10X28 goodyear slicks with a line lock. I also use 2 inch adapters with my 17X11 wheels with 6.5 BS for street driving. I never remove my adapters for my 15X10 drag slick mounted wheels.
Many years ago I purchased the 1/2 inch stud 1350 axles from Tom's. I also kind of pieced it all together over time. I have the toms #6 posi unit, custom hardened yokes, HD half shafts, 4.11 richmond gears inside of an improved case with better main caps, and HD posi cover.
I had to buy all these parts because the originals broke.
I have great faith in my 2 inch adapters with the 1/2 inch studs. I've had 6-7 years and many sets of 315 rear tires
Many years ago I purchased the 1/2 inch stud 1350 axles from Tom's. I also kind of pieced it all together over time. I have the toms #6 posi unit, custom hardened yokes, HD half shafts, 4.11 richmond gears inside of an inproved case with better main caps, and HD posi cover.
Thanks for the info! My main cocern was the wheels/adapters coming loose under racing conditions but it sounds like you don't have problems there.
I already have heavy duty half shafts and a rebuilt posi unit (3.90 gears I believe) with 2.5" long studs (I believe 7/16") on the rear. Not to mention offset arms and other VBP items installed. The way I read though, those long studs would have to go so I can bolt the adapter to the hub and wheels to adapter. If that's the case, I would say 1/2" would be the way to go for sure all the way around.
I have long studs and use 2.25 and 2.5" adapters to mount my C4 wheels for rain tires. I don't think I have a problem with the long studs extending beyond the adapters, but the C4 wheels have reliefs betweent the lug holes so it doesn't matter anyway. I'll have to check next time I have the front tires off to see if the studs extend beyond the adapters. I'm pretty sure they don't though.
I know the hub centric and wheel centric are better and probably what you want for autocross but are the non centric ok for drag or should I not consider those at all? Thanks for all the advice so far!
If they're Corvette wheels and you get VBP adapters, they'll be hub centric. I would recommend VBP first based on experience with their products. If they're not Corvette (or GM at least) wheels, I can't say that they'd have the correct bore to pilot on the adapters.
You may be getting into a cost range where you might consider some custom 17" wheels that don't require adapters. CCW, Kodiak, or similar come to mind immediately, even American Racing makes a 17" wheel that you can get custom built to fit without adapters.
