Hydrocarbons
Old Sep 21, 2006 | 05:10 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Default Hydrocarbons
I finally got the title to my 76 to go register it. Here in my county in Indiana we have emissions testing. I boughht the car from Ohio and what do ya know, the Cat was missing and they wouldn't pass e without it. They did test it though and I was ok on the CO2 but not the hydrocarbons. Is that a direct result of the Cat missing?
Also, I have a dilemma. I got a 30 day permit so I can get it fixed. However, the emissions in my county will cease to exist December 31st.
What would you guys do? Get it fixed now or wait until the first of the year and leave the Cat off?
Old Sep 21, 2006 | 05:16 PM
Twin_Turbo's Avatar
Twin_Turbo
CO2? You mean CO ? The cat does burn off HC and converts NOx, what are the values?
Old Sep 21, 2006 | 05:17 PM
MartyW's Avatar
MartyW
A normal cat converter has three jobs
A three-way catalytic converter has three simultaneous tasks:
1. Reduction of nitrogen oxides to nitrogen and oxygen: 2NOx → xO2 + N2
2. Oxidation of carbon monoxide to carbon dioxide: 2CO + O2 → 2CO2
3. Oxidation of unburnt hydrocarbons (HC) to carbon dioxide and water: CxHy + nO2 → xCO2 + mH2O
A two way converter does only #2 and #3
Old Sep 21, 2006 | 05:20 PM
Kalway's Avatar
Kalway
Could stick a highflow catalytic convertor in there for now and just yank it afterwards.
However, honestly, how much driving do you think you'll be doing in it after your 30 days is up?
Bruthish's Avatar
Bruthish
Sorry yes....CO.
My test reads...standards = 350...my test: 752 HC
CO = 3.50(standard) my test: 1.83
Old Sep 21, 2006 | 05:21 PM
Bruthish's Avatar
Bruthish
yeah winter is approaching, so I may not drive it much at all. But last year there were several nice days through December here. May want to take her for a spin.
Old Sep 21, 2006 | 05:33 PM
Kalway's Avatar
Kalway
Well, if they will pass you without having a cat, you CAN get those HCs lower without it.
Are you willing to do some carburetor work? I know you have access to ethanol...
Old Sep 21, 2006 | 05:35 PM
zwede's Avatar
zwede
An aftermarket high-flow cat is under $100. Might be worth putting one on there as I doubt it will cost you any power and you it might make you feel good?
Old Sep 21, 2006 | 05:36 PM
SIXFOOTER's Avatar
SIXFOOTER
Do the 30 day thing and see how much you can skate after that. That will get you to the middle/end of october, maybe try and beg another 30 out of them, then your down for the winter anyways
Old Sep 21, 2006 | 09:19 PM
happiedazs's Avatar
happiedazs
Help save our environment --- spring for the Cat
Old Sep 21, 2006 | 09:37 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Yeah...turn a moderate amount of nasty chemical emissions into a smaller amount of REALLY nasty chemical emissions.
Old Sep 22, 2006 | 12:06 AM
marshrat99's Avatar
marshrat99
Explain please?
Old Sep 22, 2006 | 01:34 AM
Twin_Turbo's Avatar
Twin_Turbo
yeah..heavens forbid that there is WATER coming out of your tailpipe...
Old Sep 22, 2006 | 02:33 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I'll try to find the paper I read on catalytics that discussed the function and output.
Old Sep 22, 2006 | 02:43 AM
Twin_Turbo's Avatar
Twin_Turbo
The only thing that I can think of is that there's also N2O coming out of the tailpipe and that's a greenhouse gas.....now...surely some ricer will plumb his exhaust into his NOS bottle for a free recharge
Old Sep 22, 2006 | 02:59 AM
exdrag77's Avatar
exdrag77
Originally Posted by marshrat99
Explain please?
I found an article and he's right. The way I read it the catalytic converter actually makes more greenhouse gases than if it weren't installed!
http://www.krioma.net/articles/Catal...0Converter.htm
Old Sep 22, 2006 | 03:58 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I think his chemistry is right - but he got one thing wrong right off the bat. PCV systems were introduced long before 1963 - big trucks had them in the late 30s.
To Hydrocarbons
Old Sep 22, 2006 | 07:25 AM
UKPaul's Avatar
UKPaul
No emission controls on mine at all & my CO reading was something like 0.14ppm (which is good). HC was a little high & the reason was that the idle mixture was set too lean. As it was lean the burn wasn't as efficient as it could be, hence unburnt fuel was heading out of the pipe. Richening the idle mixture brought the levels right down (but I don't know the figures), so it may be worth fiddling with the carb settings to see if you can drop the emissions down & then make a decision on the way to go.
The environment? Cats contain platinum AFAIK. Got any idea of the amount of pollution caused by getting hold of platinum? A cat reduces CO & HC, but production of platinum causes a few probems of it's own. Frequently found with platinum deposits are lovely things like arsenic & uranium, along with other "green" goodies. These cause problems all of their own (a friend owns a mine, the pollution aspects of mining it are a nightmare). Mining & refining the platinum takes energy, energy production causes pollution. Early cats didn't start working until they'd fully warmed up (don't know about moden ones). What happens to all the old cats? Landfill? HC emissions? Look out, there could be a bit coming out of your tailpipe! We'll completely ignore the gas that pours into the atmosphere every time somebody fills their gas tank, or the fumes that I've seen pouring from vents when a gas station has it's fuel tanks filled (used to work above one & the stink of petrol/gas when the tanks was filled was very, very strong). And then there's aircraft dumping large loads of fuel into the atmosphere....... Pollution, hurumph. If the "greens" looked at the planet as a closed system then maybe they'd see that the car isn't the largest polluter (but the owner can be convinced that he/she is & then become a cash cow for taxation purposes).
Old Sep 22, 2006 | 03:48 PM
694speed350's Avatar
694speed350
Old Sep 22, 2006 | 06:24 PM
mrvette's Avatar
mrvette
The total and complete enviro LIE perpetrated on the American consumers by the likes of Ralph Nader and company....LONG LIST....is just astounding.....
I KNOW the truth....and most of the public CANT HANDLE THE TRUTH!!!
