Wandering steering
Old Sep 13, 2001 | 06:23 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Wandering steering
Now that I have put the 255/60/15's on the front, my vette wanders terribly. Any suggestions?
Old Sep 13, 2001 | 06:31 PM
The Wanderer's Avatar
The Wanderer
Default Re: Wandering steering (71,454,4spd)
With new rubber and wider track ... you probably have a lot of slop in your various steering linkages. I know I have bad shocks, and find my steering is really loose at 60-65 MPH ... below and after that speed everything really tightens up.
Old Sep 13, 2001 | 08:37 PM
45ACP's Avatar
45ACP
Default Re: Wandering steering (The Wanderer)
As good a place to start as any . . .
Read this series of articles: http://www.bokonon.net/corvettefaq/c3/vip.pdf
Pay particular attention to the parts about the steering box and the idler arm.
Old Sep 13, 2001 | 11:13 PM
Bubba65's Avatar
Bubba65
Surely you had the alignment adjusted. That's adjusted, not just checked. All three angles, especially castor. By someone who knows what they are doing. I believe in keeping my castor up around 1 1/2 degrees positive. Less castor or even negative castor make the car more "responsive" but will make it wander or dart from side to side.
Also, if the 255/60s are different from stock in width or height, then the intersection point of the steering axis with the tire centerline is different from design. This will affect the toe-in/toe-out push on the tire. You will need to set the toe adjustment different from the factory specs. For example, a wider tire will move the intersection point further into the ground. This will create more toe-out push on the wheel. To compensate, the adjustment should have more toe-in than specs. And it's a trial & error thing to get it right.
Old Sep 14, 2001 | 09:21 AM
73 Teach's Pet's Avatar
73 Teach's Pet
Default Re: Wandering steering (Bubba65)
How fresh are your suspension bushings?
I replaced all the front end suspension parts, but my car still would dart left and right unexpectedly. I had the car on a friend's lift and he pointed out that the rubber bushing had squished out and that the cross shaft was floping back and forth in the metal bushing shell.
So do all the usual front end checks, but keep this one in mind if all the first line checks come up fine
"TEACH"
Old Sep 14, 2001 | 09:30 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Take the lash out of the steering box.
Old Sep 14, 2001 | 10:10 PM
LAvetteman's Avatar
LAvetteman
Default Re: Wandering steering (Easy Mike)
Anyone care to give me a step by step on removing steering box lash????
Old Sep 14, 2001 | 11:14 PM
Jim Shea's Avatar
Jim Shea
Go to: http://www.corvettefaq.com and look under Suspension and Steering. Go to Steering Gear Adjustment - In Vehicle. Also Strg Gear Adjust Pic 1 and 2.
There is also a more exact adjustment that is done with a torque wrench and it is completely described in the Chevrolet shop manual.
To Wandering steering
