lights wont go up
Old Sep 22, 2006 | 11:06 AM
Gage's Avatar
Gage
Default lights wont go up
My lights go up very slow, one goes up only 1/2 way, the other not at all. When I manually push them up with my hand to the fully locked position, you can hear the idle smooth out. Does this mean I am leaking vacuum on the actuators?
Old Sep 22, 2006 | 11:12 AM
gyopp's Avatar
gyopp
you have a vacumm leak that may be the actuators, relays, tubing, ro all of the above. Get a hand held vac pump at the autoparts store. Start at the actuators and see if they will hold vacuum. You pretty much have to test each component and go through a process of elimination. You probably have more than 1 leak if its like most of these old cars.
