spedo cable question.
Old Sep 22, 2006 | 12:02 PM
slowup's Avatar
slowup
Default spedo cable question.
Im about to switch my spedometer cable on my 74'. Is there anything that holds the cable in behind the speedometer like a clip or do you have to just yank it out?
Old Sep 22, 2006 | 12:04 PM
S489's Avatar
S489
there is a clip; you can pull the dash forward a little then get your hand on the clip while someone pulls on the cable from outside.
Old Sep 22, 2006 | 12:07 PM
slowup's Avatar
slowup
o, ok thx!
Old Sep 22, 2006 | 04:49 PM
Laird1978's Avatar
Laird1978
It is a clip, but you do not remove it. I just bends toward the face of the speedo while pulling on the cable. If you have problems my speedo is out and I can email you a pic of the back side.
Old Sep 22, 2006 | 05:01 PM
bbeck's Avatar
bbeck
yes, you don't need to remove or pull the dash out- if you're fairly small/flexible. I'm 5'10" and 210 lbs and I was able to get to mine without removing the dash. Just feel around, push the clip in with one finger and pull out on the cable with the others. Installation is simple- just wiggle it in. Once the clip snaps, give the cable a little tug to make sure it is in, and you're good to go. I laid on my back with my head at the pedals to do mine.
Old Sep 29, 2006 | 09:05 AM
S489's Avatar
S489
this may be a little late, but just popped into my mailbox:
http://www.corvettemagazine.com/2006...meter_tach.asp
To spedo cable question.
