Carb advice
Old Sep 24, 2006 | 07:36 AM
Black_80's Avatar
Black_80
Default Carb advice
I put a ZZ4 in my 1980 last year. I have an Edelbrock performer 600 on it and it runs great with a lot more power than the original motor. I have no fuel filter yet and can't run the original drop base air cleaner. I am thinking I might get a little more power with a 650. Should I:
1-keep the 600 and use the $60 Edelbrock fuel line (that hugs the carb) and filter and $40 fuel line. Not sure if the air cleaner will clear the auto choke to allow the original air cleaner but I would otherwise be ok.
2-Change the carb for an Edlebrock Thunder 650 with the fuel line and filter above.
3-get my original Q-jet rebuilt, add an electric choke, and set up for the ZZ4. Who should I have do this? Does Lars still do this? This would get me my a fuel filter and the original air cleaner. I have rebuilt carbs with kits but am not at all sure I can tune it right for the ZZ4 motor. I see a Haynes manual for q-jets.
Thanks for any advice.
Old Dec 23, 2006 | 11:31 AM
BigBlockk's Avatar
BigBlockk
Rebuild the 'Jet yourself. We can step you through the tuning.
BigBlockk
Later.....
Old Dec 23, 2006 | 01:29 PM
a1sensei's Avatar
a1sensei
Old Dec 27, 2006 | 02:51 AM
duntovlives's Avatar
duntovlives
Old Dec 27, 2006 | 09:14 AM
spedaleden's Avatar
spedaleden
[QUOTE=Black_80;1557028414]I put a ZZ4 in my 1980 last year. I have an Edelbrock performer 600 on it and it runs great with a lot more power than the original motor. I have no fuel filter yet and can't run the original drop base air cleaner. I am thinking I might get a little more power with a 650. Should I:
I did the same thing two years ago. I used the original air cleaner because I liked the way the stock set up got cool air to the motor. I did cut out bottom sections of the air cleaner for linkage issues and choke. I had a Edelbrock 750 which was good. Per the forum and others I changed to a Holley 750. Just got it dialed in (Lars Tuning)and a BIG difference, a lot more power. Still using the original air cleaner.
Old Dec 27, 2006 | 01:45 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Nice pics spedaleden
Old Jan 27, 2007 | 07:59 AM
Black_80's Avatar
Black_80
Thanks for the advice! I have decided to redo the Q-jet. I read the Doug Roe book and bought the new Cliff Ruggles book. My Q-jet is completely dissassembled and clean. I am now in the process of following one of Cliff's "recipies" that involves measuring everything and slightly resizing some of the holes for the best transition from idle to off-idle to part throttle to full throttle. I sent him an email with questions and he told me to call him. We talked for about 45 minutes. He could do the work for me but he is backed up through September so he gave me some more help on the phone. If I do most of the work, he can rebush my primaries and reduce the size of my main air bleeds and turn it around in a week. I will be enlarging my idle tubes, accelerator pump discharge holes, secondary tube restrictions, etc. If he is right and I do things right, this should come out great. I might just do a little fine tuning following his and Lars suggestions.
Old Jan 27, 2007 | 08:21 AM
noonie's Avatar
noonie
Makes a big difference. If you do all that to the qjet you will be very happy with it.
To Carb advice
