Ditching the stock Steering Column
what to do about a steering column. I'd like to keep the taper and splines on each end, be collapsable, and I would like sealed roller bearings. Any ideas?
Street Rod?
Dirt track?
Road race?
I guess I can also make my own out of some DOM tubing and OTS bearings.
TT presents an nice option... I forgot about Speedway...
The vette colum is long 38" or so...
Issues...
1 the new dash layout is space constrained so making the column housing as small as possible is goodness. Picture a ladder frame (0.065 wall 3/4" square tube) across the dash and the console dropping down... 5 panels with dzus buttons that pop out to work behind...
Left - Electric/Fire Pull
Left Center -Tach/Speedo/turn/High/brake
Center top - Oil Press/oil temp/Water temp
Center middle Fuel Qty/Fuel Press/Volts
Center bottom - Trans temp/diff temp/vac
Right Pass - Laptop/LCD with GPS/and Engine Mgmt SW
Center console - Electrical and fuses
2 the turn signal stalk is in the way when getting in and out of the car.
3 I need to locate the battery master and fire bottle pull on the left most side of the dash again the turnsignal is in the way
I'm not sure how the turn signal stalk could get in the way when entering and exiting the car.
