82corvetteC/E
Old Sep 26, 2006 | 06:34 AM
warrior2291's Avatar
warrior2291
Default 82corvetteC/E
I know this may sound stupid but here goes.I am only a novice but have found this site to be helpful in may ways to me.
I have a 1982 C/E. I notice that while driving I have a strong smell of exhaust fumes in my car. I have had it put on the lift and has the mechanic checked the exhaust system. There are no leaks in the exhaust system.
Has anyone ever had this kind of problem??
Thank you for all your help!
Old Sep 26, 2006 | 08:33 AM
flynhi's Avatar
flynhi
Have it checked again by someone else. Also check manifold gaskets and the seal at the ear of the hood. You may be leaking at the manifold and sucking it into the cabin thru the cowl vent on the passenger side.
Old Sep 26, 2006 | 12:10 PM
warrior2291
Default 82collector
Ok I will do that sir and thank you for the help. I will take it this weekend and see if it shows up anywhere.
Old Sep 26, 2006 | 12:37 PM
Twin_Turbo's Avatar
Twin_Turbo
check the evap canister, it's between the drivers side fender gill and the frame, a large round can. Maybe it's full of fuel and the purge system is not working properly.
Old Sep 26, 2006 | 09:25 PM
Toms82's Avatar
Toms82
Hi,
My CE used to run very rich before I had some work done on the fuel injection. The smell of the rich exhaust is drawn into the car for some reason. I don't know of any areas on my car's body that would leak exhaust and the exhaust system itself is sound. Have your mechanic look at the injection system, it could be as simple as a bad coolant sensor.
Good luck,
Tom
Old Sep 28, 2006 | 09:22 AM
warrior2291
Default 82collector
Thanks for the help on this one. i took it back to the dealers they checked the system I have no leaks in the exhaust system.
I will check this can out this weekend and see what I can find out.........
I had the ejectors cleaned last week , let me say that differently I had the throttle bodies cleaned and changed all the filters. I also replaced the plugs too. I cant seem to put my finger on it but I still smell those damn fumes , however i did notice when I put the switch to vent it seems to lighten up a bit.
About 2 months ago i puit a new fuel pump in and a new fuel relay. We check that out put a gage in the fuel line and its puting out about 12 PSI I believe. But I notice that every once and a while when I step on the gas i get a miss or it cuts out but it is interment.
So what ever i got going on I am closing it on it I hope.
Some background on the car it only has 41k originial miles it sat for quite a while. So i fighure things are just dried out perhaps. Thats why the fuel pump went bad they left the tank empty for years. I cleaned the tank out and put a new fuel pump in along with the relay it seemed to do fine for 2 months now i am getting this interment problem......
Old Sep 28, 2006 | 10:58 AM
moosie982's Avatar
moosie982
How is the seal (weatherstripping) on your rear glass ? If it isnt sealed tightly it might be sucking some exhaust fumes thru. Peace,,, Moosie
Old Sep 28, 2006 | 09:29 PM
warrior2291
Default 82 collector
you are a genius my seal is not even touchinh the glass at the top all the way around.........looks like I found the problem or I should say you did thanks a bunch!!!!!!!!
No were to get a seal cheap?
Old Sep 29, 2006 | 04:10 AM
stingr69's Avatar
stingr69
Bad seal or bent hatch hinges?
-Mark.
Old Sep 29, 2006 | 11:42 AM
warrior2291
Default 82collector
Bad seal I can see daylight all the way around the top edge..........
Old Sep 29, 2006 | 11:58 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
That could still be bad hinges. Someone on here was making upgraded replacements, an archives search would be in order.
Old Sep 29, 2006 | 12:26 PM
bluedog20175's Avatar
bluedog20175
Default Hinges
If you have had to replace the hatchback struts, there is a possibility that when using reproduction or new manufactured struts, they could have bent the hinges due to the stress when struts are compressed.
I found a set of original struts at Corvette Salvage when I replaced mine, as the repro struts put a lot of pressure on the hinges and caused my hatch not to close properly. After all the stories of the repro struts causing bent hinges, I didn't want to tempt fate.
Apparently also, if you have replacement hinges, they may also tend to bend easier. Fortunatley I haven't had to do that...
Old Sep 29, 2006 | 12:34 PM
simpson36's Avatar
simpson36
I'm the guy who made the replacement hinges. I made a set for my Wife's CE and made a few more sets while I was at it, but they are all gone, sorry.
Occationally, original hinges show up on e-bay for rediculous prices. The last set I saw on there was $500 and the guy claimed they were 'not sprung', but that's BS, they ALL stretch open.
All of the CE's I was involved with had the hinge mounts and/or latches butchered up to different degrees by people trying to get enough adjustment to seal the glass. It won't work because the hinges just stretch more.
You can take the hinges off and squeeze them back to their original dimension and reinstall them. If you take off the gas struts, you can't use the hatch, but at leaste the hinges might keep the glass sealed.
The new window seal is still available in repro, but it's a bit expensive. .
Old Sep 29, 2006 | 12:47 PM
simpson36's Avatar
simpson36
Bluedog;
What 'replacement hinges' are you talking about?
The only hinges other than the originals that I am aware of are the few sets that I custom made from solid 6061-T6. The hinges I made do not stretch.
http://www.thecubestudio.com/picture...tallRear01.jpg
Compare . . . the black hinge it the original.
A forum member here (copter) has one of the sets I made.
Old Sep 29, 2006 | 01:02 PM
RBarnes's Avatar
RBarnes
To answer the "where to find a seal" question. There are numerous sources. Be very careful who you buy this thing from though. I have heard of unsuspecting souls paying the traditional $200 or so only to recieve a seal stamped "Made in China". (I'm still trying to figure out when China made Vettes, but hey) To add insult to injury, they do not fit very well and look even worse.
Corvette Rubber and GMPartsDirect.com both have positive feedback associated with their rear seals.
Hope this helps!
'05 Precision Red Z51 C6
'82 Collector's Edition C3
Old Sep 29, 2006 | 02:49 PM
stingr69's Avatar
stingr69
Reason I said that was I have heard that CE's have had a common problem with the hatch hinges bending. That might cause daylight around the seal.
Not that I know that much about CE's but it would be something to watch out for. Maybe another CE owner will enlighten us.
-Mark.
Old Sep 29, 2006 | 03:37 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Simpson, if you're not planning to make any more hinges, do you have any drawings or measurements that you could send to the CE guys who need them? I'm sure just about any machine shop could make them.
I don't have a CE, not looking to get one, but I know that this is a common problem.
To 82corvetteC/E
Old Sep 29, 2006 | 11:03 PM
bluedog20175
Simpson;
Merely going by what I heard when I bought my pistons. I was warned off of repro hinges because they bend. Haven't had to go there, thank goodness. Glad to have you clear that issue up, since you made the repros.
Old Sep 29, 2006 | 11:58 PM
SuprJames's Avatar
SuprJames
Originally Posted by bluedog20175
Simpson;
No, he made a few sets of custom hinges that are NOT going to bend. The stock ones are made of cheap metal that easily bends, so it's actually the stock ones that bend and not his custom hinges. There are no true reproduction hinges for the CE, so whoever told you that was misinformed.
Old Sep 30, 2006 | 08:33 AM
warrior2291
I have re-thought this process out all over again since I have read so much info here on this site. I think I may need to have this professionaly done.
Do you have any idea who or where I should take the car to?? Maybe a glass place??
I got the hatch opened last night and I looked eveerything over here is what i have found.
First the glass does not seal all the way around the the seal at all. from the top and both sides I can see daylight.
I would not know a new set of hinges fom old but what I can tell you is that they are black at the top. Now as for the struts I think they may be new they look new and I remember when I bought the car that the litte plastic piece that goes around the botton of the strut was loose. I fixed that but any way I think they are new.
In no way am I that good to take this job on so got any ideas who
to take it too.
P S I went out to the garage this morning and i took some pics I looked the glass seal over closely I noticed that the glass does not seal at all all the way from the top and around both side of the seal, in fact i can see daylight all the way around
