Transmission speedometer gear question
Old Sep 26, 2006 | 11:44 AM
dd69bb's Avatar
dd69bb
Default Transmission speedometer gear question
I just got my transmission back from overhaul and I need to put in a speedometer gear. I looked through the AIM but I can't find which one to put in. Anyone enlighten me please? It's an M21, 3:36 rear end and P235 70R15 tires.
Old Sep 26, 2006 | 12:33 PM
Tonys96's Avatar
Tonys96
I'm thinkin' a 20 tooth will get you close.
I'm just installing a 3.36 in mine, just regeared the speedo from the stock 20 to a 22 for the 3.70 that I just hand grenaded. Stock ratio was 3.36 and had a 20 tooth, but M-21's could have a 7-8 tooth drive gear so without taking the tailshaft housing off and counting the drive gear teeth, you may need to try a couple of different driven gears.
Old Sep 27, 2006 | 01:59 PM
dd69bb's Avatar
dd69bb
Thanks. I'll give that a try
Old Sep 27, 2006 | 03:03 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The tranny gears are color coded. Your Bowtie man probably has a chart and can tell you the exact gear you need.
Old Sep 27, 2006 | 03:59 PM
corvald's Avatar
corvald
Ithink the 3.36 use the green color.
Old Sep 27, 2006 | 08:56 PM
DIRK73's Avatar
DIRK73
Navigator
My stock 73 with 3.36 rearend and M-21 trans had a 18 tooth brown colored gear.
Old Sep 27, 2006 | 10:27 PM
mdj21's Avatar
mdj21
this site has a calculator that should help you.
http://www.tciauto.com/Products/Tech...eedo_gears.asp
good luck and i hope this helps,
Mike.
Old Sep 28, 2006 | 02:02 PM
dd69bb's Avatar
dd69bb
Thanks for all the replies
Old Oct 2, 2006 | 07:18 PM
asianlimodriver's Avatar
asianlimodriver
Default Speedometer Accuracy
Can anyone help me out with my speedo accuracy? I have a 72 and know that my speedo is not accurate. It shows me doing 100 mph at about 3200 rpm. The only thing is I'm barely passing traffic that I estimate at 70-75 mph. Does anyone know of a good speedo shop in southern California that could help me dial in my speedo?
Thanks all.
Old Oct 2, 2006 | 09:06 PM
CheckerVette's Avatar
CheckerVette
I found a very detailed information list gears etc on Bowtie overdrive website. It allows you to fill in blanks in several formats to arrive at what you need to know!
To Transmission speedometer gear question
