Question about alignment specs
Old Sep 26, 2006 | 03:29 PM
LS-Five's Avatar
LS-Five
East bound and down...
Default Question about alignment specs
Ok guys bare with me here, I am not very knowledgeable in the area of alignments. I am just now getting my car to the point where I would even consider the occasional autocross, up until now I have only been concerned about what the car would do in a straight line.
I was comparing aligment specs between VBP and Guldstrand's recommendations. I have found they are very similar in most areas, aside from caster.
VBP recommends + 2.75 degrees across the board whether the car is a DD or a race car.
Guldstrand recommends anywhere from + 1.5 deg for a DD to +3 deg for a race car.
How noticeable are the effects of caster for everyday handling? My car will spend 98% of the time on the street, with maybe 1-2 small autocross events in the year.
Also, another stupid question, how do you adjust caster on a stock front end?
Old Sep 26, 2006 | 03:50 PM
LS-Five's Avatar
LS-Five
As it stands right now, I plan on having the car aligned to these specs:
Front/ Rear
Toe 0" / 1/8"
Camber -.50 deg / -.50 deg
Caster +2.75 deg
Given the use of the car, does anyone see anything wrong with these specs?
Old Sep 26, 2006 | 04:03 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Front/ Rear
Toe 0" / 1/8"
Caster +2.75 deg
If the roads in your area are crowned for rain runoff, then use 1/4 neg on the right side camber, if you are ging to run 1/2 neg on the drivers side.
Camber is adjusted by adding/removing EQUAL THICKNESS on the shims between the control arm shaft and the frame.
Old Sep 26, 2006 | 07:22 PM
LS-Five's Avatar
LS-Five
:o oops. I meant to say caster not camber.
Old Sep 26, 2006 | 07:45 PM
tracdogg2's Avatar
tracdogg2
Caster is adjusted by adding or removing shim(s) from the front or rear upper a frame bolts. Caster gives hi speed stability. The more caster the more the front end fights to keep it straight. More caster also increases turning effort. 10 degrees caster would help keep the car straight at 150mph but would take both hands to turn the wheel at 10 mph.
Due to frame sag, worn or settled bushings, or bent parts you may not get to 2.75 castor. .5 neg camber on all 4 wheels is fine. Toe-in between 1/16- 1/8. You don't 0 toe. Car will be darty under braking. Also you need someone to sit in the car during the alignment or something to equal your weight. Specs can change more than half a degree.
Get a printout before and after they do the alignment so you can post the numbers for us.
Mike
Old Sep 26, 2006 | 10:35 PM
LS-Five's Avatar
LS-Five
Ok, thanks for the info. Can you explain the variance between the recommended caster between what VBP recommends vs. what Guldstrand recommends?
Old Sep 27, 2006 | 12:58 AM
tracdogg2's Avatar
tracdogg2
It really depends on what kind of driving you are doing. Let's say you are driving on the autobahn. Hi speeds and graceful curves. You would want to run as much caster as you can. But if you were driving a low speed autocross with a lot of tight corners you would want less caster since you don't need the hi speed stability and you would have reduced steering effort. Wheels and tires with more offset compared to stock require more caster to compensate for rolling resistance. There is no magic number for caster. All you can do is try different amounts and see what suites your driving. For a street driven vette 1 1/2- 2 degrees is a good starting point.
Mike
Old Sep 27, 2006 | 07:13 AM
LS-Five's Avatar
LS-Five
Ok, thanks for the explanation.
Old Sep 27, 2006 | 11:54 AM
SanDiegoPaul
Caster is also what returns the wheel to center after you turn. Just like a caster wheel on an office chair, it is actually a form of drag-behind type of a setting. It is adjusted by adding/removing UNequal amounts of shims or moving shims in position, so that the geometry changes enough to cause the change. It is not a visual setting; you have to do it on an alignment rack.
Why are Gulstrand's settings different? Possibly because they are expecting you to be using thier modified suspension? Just a guess.
Old Sep 27, 2006 | 01:32 PM
norvalwilhelm's Avatar
norvalwilhelm
I like to put as much positive caster as possible in a car as long as it has power steering. You can run up to 8 degrees on the newer cars for good straight line running. On our vets with modifications you can get around 5 positive and it makes the car run true down the road.
Try for as much positive camber as possible but the most important thing, THE MOST IMPORTANT is to have the specs the same side to side. Don't just let the setting fall within specs, they MUST be the same side to side.
So set the caster as positive as possible, I don't like alot of negative camber because the tires at rest look like the suspension is sagging so I set it close to zero with only a slight negative preference but again equal.
I set toe at toe in about 1/16.
Old Sep 27, 2006 | 01:52 PM
69autoXr's Avatar
69autoXr
Originally Posted by norvalwilhelm
Try for as much positive camber as possible but the most important thing...
I think he meant to say caster.
You guys have to keep your alignment parameter talk straight or you'll confuse the noobs!!!
Old Sep 27, 2006 | 02:10 PM
timemender's Avatar
timemender
Mike
For the street run as much caster as the car will allow, and if you have the stock A-arms that will not be a lot - unlike modern cars. If your car is a non-power steering car, steering effort will increase along with the caster angle.
Old Sep 27, 2006 | 02:14 PM
timemender's Avatar
timemender
You were correct the first time.
Old Sep 27, 2006 | 03:26 PM
LS-Five's Avatar
LS-Five
Ok, sounds good. My car is P/S equipped so I will tell them to shoot for as much caster as they can get.
Anybody else have any contributions that they would like to make? The car goes into the alignment shop this afternoon.
Old Sep 27, 2006 | 08:01 PM
LS-Five's Avatar
LS-Five
Well, bad news. I just thought that I was going to get my car aligned today. When they checked the front end we discovered that I have two bad lower ball joints. The worst part is that I rebuilt the entire front end only 700 miles ago.
I hate fixing the same stuff twice.
Oh, well I guess I will just have to suck it up and go on.
Old Sep 27, 2006 | 08:31 PM
norvalwilhelm
You can change ball joints without removing the spring. Just have a good jack under the spring holding it up. It really isn't that bad a job and since it was out 700 miles ago the bolts should come out easy
Old Sep 27, 2006 | 10:08 PM
LS-Five's Avatar
LS-Five
Ok, thanks for the tip. I can't believe that the ball joints would be shot so quickly. I know for a fact that they were lubed properly, because I did it all myself. It must have just been a bad batch.
Old Sep 28, 2006 | 02:08 AM
Kalway's Avatar
Kalway
Did you use rubber or poly when you rebuilt em?
I set my alignment up to VB&P's autocross specs because I drive like 5 miles a day and it rains here like twice a year. Toe out is great for autocross but don't dare take your hands off the wheel because it will TURN on you. I have my front toe out just a tad with the rear toe in a tad. Handles rather good for autocross that way.
Old Sep 28, 2006 | 08:45 AM
LS-Five's Avatar
LS-Five
I used poly bushings when I rebuilt the suspension. While I don't plan driving in the rain, the roads here in Arkansas can be pretty bad at times. Lots of wear ruts in the road from big rigs loaded too heavy.
To Question about alignment specs
