Does anyone know if the 1979 L48 came with flat top, flat top with valve relief or dished pistons? I ask because I'm considering an Edelbrock Power Package (cam, intake and heads) for my Vette's stock 350. If I were to go with the 410 hp/408 torque set up, what size headers/exhaust will I need? I'd like to put the compression ratio between 9:1 and 10:1 (in other words, pump gas friendly).
Thanks in advance,
Thanks in advance,
- Chilli
dished w/ 4vr ... anywhere from 0.025" to 0.045" down in hole. DON'T use the RPM cam ... you will NOT have enough CR for it when you use stock L48 pistons & stock-deck block ... even with 64cc heads ... thinnest gasket I know of that's qualified for Alum heads is 0.026" (Victor Reinz/Napa 5746). Reduce your expectations for hp.
Thanks, Jackson. Does anyone have any idea what my new CR would be if I used 64 cc heads with the head gaskets Jackson mentioned, assuming the block has NEVER been milled (and what the maximum cam lift would be that I could use with said CR)?
- Chilli
You cannot know without first measuring how far down in hole pistons are ... but based on about -12cc piston dome volume and the down in hole spread ... SCR range about 8.9:1 to 9.3:1. Some folks guess & get lucky on a workable combo ... more often result's less than optimal. VR5746 gasket volume is 5.4cc. Use of a CR calculator's highly recommended when planning; here's a pretty good one:
I just finished an engine close to this combo. Flat top pistons with 4 relief, squared and deck the block to achieve .015 below deck, 64cc iron eagle heads, and a Fel-pro .039 comp head gasket. Ended up with 9.8 compression and .055 quench.
Mike
Sorry
410 hp/408 torque was all that was posted
What RPM do you calculate to produce 410 hp/408 torque?
Using algebra, Bob, it comes out to 5300 rpm. That is the rpm you need with 408lb/f to get the 410hp. I know where you're coming from but it's not relevant to his question, which was a concern of overstressing the block from torque and that's the question I answered.
Compression is where the power is at, but with crappy gas and expensive gas prices.... 9:1 - 9.8 compression and 300-350 hp is a pretty good place to be for a street car. Any more and you're gonna have to get flat tops.
I've got a short block with the rpm cam in it all it needs is heads. I did not like the performance with this cam but this was with the stock 882 heads.
What would be a good overall combination of cam, heads, manifold to put on an L48. I have a 76 that I am pulling out and would like to use the orginal block if I could
Mike
I believe quench is the total distance between the piston's outer top edge at TDC and the bottom surface of the head. This distance (I think) is made up of the deck height added to the head gasket height. I could be wrong, because according to my math, the above mentioned quench should be .054, not .055. The outer EDGE of the piston is used in the measurement because a dome (aka "pop up") or dish does not factor into the quench equation. Please, anyone, correct me if I'm wrong because I VERY recently asked this same question on a different site.
You are correct. Ideal for a steel rod engine is .040 (though you can go lower but don't be surprised to see witness marks once you get close to the .020s) and .060 for an aluminum rod engine. Though setting up ideal quence is a blueprint operation that you can do only after some preliminary machine work. Few people bother.
According to the Edelbrock site, the 410 hp comes at about 5600 rpm while the 408 torque comes in at 4500 rpm.- Chilli
But keep in mind ... to achieve those numbers in a 350 the motor must have right at 10:1 SCR ... meaning flattops, zero or near-zero deck and gaskets for optimal quench. And most folks do not like the RPM cam in street car.
... Although I like 0.030"-0.040" quench w/ steel rods.
