off set control arm needs
Old Sep 26, 2006 | 06:16 PM
Joe45's Avatar
Joe45
Default off set control arm needs
Question... In the process of a frame graft. Not knowing if shims were present for the front upper control arms on the front frame 1/2 I purchased and plan to install is there a dimension I can use to determine if I can use std. control arm shafts or offsets? Maybe center to center on the upper shock tower holes? Maybe someone can send me this dimension on a car with shims installed? Or... can offset shafts be used whether or not they are really needed?
thanks
Old Sep 26, 2006 | 11:26 PM
72LS1Vette's Avatar
72LS1Vette
BarryK's website has frame diagrams for older and newer C3 frames that might be of some help. You could try asking Dan at Van Steel about the offset cross-shafts. Dan is very knowledgeable and helpful even if you are not a paying customer (you will be at some point ).
Rick B.
