Shimming rotor help
I have no idea if you can rent the dial indicator and stand, but I don't see why not. They're not an unusual tool, and you could buy a cheap one with stand for probably around $75.00.
Not sure how much you want to spend here's a good web site.
As someone else suggested in an earlier thread, I just purchased a
dial indicator with a magnetic base from Grizzly Co. It also came
with a dial caliper. Total cost with shipping was $41.20.
Their item no. is H3022.
You can get a magnetic base dial indicator at Harbor Frieght a lot cheaper than anywhere else.
I used a Grapette cola can ( some use a beer can) to cut out the shims when I did my rotors.
I also used white paint on one of the studs and marked a white spot on the rotor when I got done, so that if I ever took them off, I would know the correct position when I put them back on.
got mine on fleabay for $50 after shipping.... excellent tool to have.
I purchased a Brass sheet .005 4"x8" from Ace Hardware for $2, but it took 30 minutes to find it, no one knew what I was talking about. It was by fluke the clerk found a display with brass/tin/ss metal pieces, pipe, etc. It was packaged in an area and labelled as KMS (or KSM?) Metal Product or something like that. They did actually have a package called Brass shims, but didn't label the thickness, I guessed it had 2 .005 and 2 .002 small sheets. But I opted for the single .005. It worked fine for my 2 front rotors.
I used tin snips to cut a small circle (used a bleach bottle cap as a drawing guide). I then used a 1/2 inch drill bit to notch a hole in it to clear the bolt threads so it wouldn't bind up.
I now need to do the rears..
Hope this helps out.
Criss
Each circular shim I cut was .003 thick. Didn't need any thicker to get rotors within .002 of runout. Used nothing but the best imported beer can for my ride!
Eddie
I'm assuming this is for rear rotors? regardless they can be dialed in as long as the spindles are not bent. Be sure there is no rust or burrs on the mating surfaces. I only dial in rotors when I can secure them to the flange or hub with flat heads. I do not rely on the lug nuts to hold the position, this will change everytime you remove a wheel. I know many use the lug nuts only but if you want the better job bolt them on. You don't need to rivet them and riveting is only good when you can turn the spindle and rotor as one. Bolting on gives you the opportunity to remove and dial in the shims.
If you have never used a dial indicator there are some things to learn. First you have to 100% sure there is no movement in your fixturing, the slightest pressure will throw off your readings.
Next I know the chinese indicators are cheap, I have some too, but they are junk. I've had the 2 or 3 here last only a short time and then start sticking. This is worse then the first problem because the reading will appear good then start to drive you crazy!
I use SS shim stock from MSC, it comes in kit form from .001-.020" I punch out the holes with a sheet metal hole punch kit. These 2 will set you back about $80- $100 so I would look around a good hardware store, You'll need a micrometer or caliper too.
It is important to get the runout under .002" I've heard up to .005" is good but you're going to be the one driving the car so why do it 1/2 way?
If you don't have any of this stuff and don't plan on doing much wrenching on your car then find someone to do it for you. If however you plan to really work on a vette you're going to need the indicator, micrometer, calipers, and a lot of other tools.
Here are some pictures from a front setup
