Chevy crate ZZ572
Old Sep 26, 2006 | 10:56 PM
AWilson's Avatar
AWilson
Default Chevy crate ZZ572
Anyone know if a Chevy crate ZZ572 would fit in a 68. Would I need any upgrades to suspension, stiffening frame, etc. How about tranny choices? Can I use my stock 4 speed tranny?
Old Sep 26, 2006 | 11:00 PM
GDaina's Avatar
GDaina
you will have to fabricate a set of headers, as that motor uses the tall deck block. It is a good idea to replace worn suspension pieces with new...
Your tranny will hold up if you don't go crazy with the shifts.
Old Sep 26, 2006 | 11:18 PM
L88Plus's Avatar
L88Plus
Check out the pump gas 555 at Scoggin-Dickey, listed under their Street Warrior engines. It's a short deck engine that makes more torque (675) and hp (710) than the 572 (620hp/650tq) and it's not even $1000 more. It uses the same hydraulic roller cam, Dart Pro 1 heads and a Dart Big M block and are hand-fitted and blueprinted. They're actually closer to 750hp with the new ones - I've watched 'em dyno tuned. The 572 comes with no warranty, same as the 555. Email me at 81vette4speed@***.net, I have all the info you need on these strong running beasts.
Old Sep 26, 2006 | 11:31 PM
72LS1Vette's Avatar
72LS1Vette
I don't think the Muncie 4-speed will hold up under that kind of torque unless you drive it pretty conservatively. And if you drive it conservatively you don't need that kind of torque. You probably need a Viper 6-speed behind that big motor.
Rick B.
Old Sep 27, 2006 | 12:39 AM
kaiserbud's Avatar
kaiserbud
Originally Posted by L88Plus
...... torque (675) and hp (710) than the 572 (620hp/650tq) an........... They're actually closer to 750hp ..............
Old Sep 27, 2006 | 12:40 AM
PRNDL's Avatar
PRNDL
Rick Moroso put one in a 68, but apparently took it out! I don't know why, but he would be a good person to ask. You would need a taller hood, and I am not sure if an L-88 hood would be tall enough.
Old Sep 27, 2006 | 01:29 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Someone asked the same question about three days ago.
Old Sep 27, 2006 | 07:47 AM
GDaina's Avatar
GDaina
Rick B.
The Muncie will hold up....power shifts is a no no as the rear will be first to go, then the Muncie. You can shift fast and still keep the equipment from breaking.
Old Sep 27, 2006 | 01:02 PM
BB wowbagger's Avatar
BB wowbagger
I send about 640ft/lbs through my Muncie and it holds up just fine (knock on wood ). Just dont use slicks.
Old Sep 27, 2006 | 01:52 PM
panic's Avatar
panic
mine is holding 530tq with gentleman elegance and proudness, even if i like to shift hard approching snaky bends...
i love my slim yet strong 4 speeds muncie trans
Old Sep 27, 2006 | 01:57 PM
68 NJConv 454's Avatar
68 NJConv 454
Check out the pump gas 555 at Scoggin-Dickey, listed under their Street Warrior engines. It's a short deck engine that makes more torque (675) and hp (710) than the 572 (620hp/650tq) and it's not even $1000 more..
Over 13 grand for an engine......
If I had the money its a very nice engine with monster power.
Old Sep 30, 2006 | 08:59 AM
AWilson's Avatar
AWilson
What size tires would I need to handle this beast.
I know it depends on alot of thother things but what kind of numbers might I get at the track with this kind of power?
To Chevy crate ZZ572
