LS5 Camshaft
Old Oct 1, 2006 | 12:13 PM
SmokinBBC's Avatar
SmokinBBC
Default LS5 Camshaft
I am looking for a replacment camshaft for my '70 454/390.
Searched through the archives and found quite a bit about cams, but nothing about a direct replacement(stock).
Is it possible to get a direct replacement? Is there a better cam that delivers similar performace on HP/TQ (390/500)? As far as I can tell, the specs for stock are H, Lift 461/480, Duration 350/352, ration 1.7.
For the most part I am good at making repairs. I can follow the procedures without a problem. (also have built up a nice tool set). But I get lost when trying to understand technical specs. So, of course, my usual decision is to stick with stock.
Thanks,
Paul
Old Oct 1, 2006 | 12:34 PM
greg454's Avatar
greg454
Crane cams still make that cam.
Greg.
Old Oct 1, 2006 | 01:01 PM
zwede's Avatar
zwede
Here are two cams that will make more power with the same idle and drivability as stock:
http://store.summitracing.com/partde...5&autoview=sku
The second cam is more money but has a newer design and makes better power.
You should also replace your valve springs.
Old Oct 2, 2006 | 09:41 PM
sxr6's Avatar
sxr6
I agree with Zwede
I would pick the Lun 60202
Well actually I picked Lun 60203
To LS5 Camshaft
