Turn signal problem
The shop manual says to disconnect the signal switch connector from the body harness at the steering column. Connect a spare turn signal switch to the body harness and see if the problem is fixed. (Of course this assumes you have access to a spare switch.) BTW, virtually any GM switch (standard column, tilt, T&T, etc) with the same connector could be used.
Jim
I think you might be on the right track since I just changed the flasher and it did not fix the problem. Since the turn signals worked fine up until last week can I assume that the switch went bad? I think it would be odd that a ground suddenly goes bad creating thhis sort of problem or am I wrong in making that assumption?
Could be ground wires or internally in the sockets.
Check with 4 way hazard switch or brake lites. Both use the same wiring, bulb and ground.
If any of these work, then you test for the switch.
I would suggest that you try and beg, borrow, or steal a spare turn signal switch so you can connect it to your cars electrical circuit to check for a bad switch. Removing and replacing a switch from a T&T column is not all that bad, but I can think of better things to do with about 3 or 4 hours time.
The turn signal switch can be removed and replaced without removing the steering column from the car. However, it is my opinion that working on the steering column is far easier if it is out of the car. I have complete instructions on removing the turn signal switch as well as removing the steering column from the car. You only need two special tools. You need a steering wheel hub puller and you need a locking plate compressor tool so that the locking plate can be depressed a short distance while you remove the C-clip that holds the locking plate in place. These tools can usually be borrowed from your local Autozone or other automotive retailers.
Go to this websight:
http://jimshea.corvettefaq.com/
Click on: Corvette Steering Papers in the right column
Scroll down to the the bottom and click on the following:
Tilt & Telescoping Column 69-82 Disassembly & Repair Papers #1 and #2
Tilt & Telescoping Column 69-82 Disassembly & Repair Pics #1
Oh, by the way, you will most likely find that after removing the steering wheel and hub that there is a plastic retainer that is down on the steering column shaft. When you try and pry it up and off of the steering shaft, (this is just before you use the locking plate compressor tool) it will most likely crumble into many pieces.
It can be purchased from GM dealers part #7808385 - Retainer
Or from the Zip Store part #SC-517 Cancelling Cam Plastic Retainer
Without the retainer the big spring that is attached to your steering wheel hub will touch metal column parts and your horn will blow continuously. So even though they only call it a retainer, it is also an insulator.
Good luck,
Don't forget that additional help is only a computor click away!
Jim
1) Sprayed WD-40; no change
2) turned hazards on; all lights flashed except the driver's side front. This bulb was the one that gave me so much trouble when I tried to remove the bulb. I eventually had to break the bulb and remove the metal end with needle nose pliers.
3) When I turn the parking lights on the driver's side bulbs seem to be brighter than the pass. side.
4) If I manually blink the driver's side bulbs by switching the turn signal lever; the rear tail light gets brighter like normal but, the front bulb just stays bright.
Now what?
Do it 2 ways
1- by grounding to the socket ground.
2- by grounding to the battery or known good ground.
Not common but, these sockets do go bad internally and it only takes one on a side.
Any suggestions would be appreciated; I don't want to damage the fiber optics by getting too impatient or trying something stupid.
